Question about FAIP Vertical Shaft Pump MTPV82684
FAIP Vertical Shaft Pump MTPV82684 - FAIP Vertical Shaft Pump MTPV82684
What kind of pump oil
What you have is a generic pump from china more than likely. Its built along the line of a FAIP pump. They arent supposed to have the oil changed in them at all. Most are sealed pumps but may have a plastic plug in it. If you must replace the oil then I would suggest Pressure washer parts catalog quick links Pressure Washers High Pressure... and get this item 4.5 OZ. AR64545 OIL FOR AXIAL PUMPS. It is recommended for pumps built similarly but not for your specific pump. But it should work. Good luck. W
Feb 21, 2015 | Simpson MSV3025-S Megashot 3000 PSI Honda...
What will couse the pump not to build pressure
To many things to list.
i recommend giving our free tech support person ell a call when you can be at the washer and they can walk thru the process of diagnosing it.
1-888-279-9274
Oct 21, 2014 | FAIP Vertical Shaft Pump MTPV93501
How often do you fill pump wit oil?
Pump oil doesn\'t need to filled often. Only when you notice the oil looking creamy or not clear! This applies only to horizontal shaft pumps! If you have a vertical shaft, the pump is non-serviceable. If the pump is leaking oil, then only add as needed! The oil level on any pump is half way up the sight glass if any is available. If no sight glass is available then only half way up! NEVER fill the pump completely up! This can cause oil seals to fail as well as other damage to the pump! Best of luck!
Sep 26, 2014 | Garden
I have a honda HRA214 motor i took out of a push
you cant convert a vertical shaft motor to a horizontal
Sep 13, 2014 | Cars & Trucks
How do I replace water pump
1.remove the bolts securing the water pump cover to the engine front cover and remove (3 bolts) watch out for the dowel pins
2 remove the remaining bolts securing the engine front cover and remove cover and gasket(8 bolts) watch out for the dowel pins and the o-ring seals around the openings
3 remove the bolts securing the water pump and remove water pump.watch out for o rings
4 rotate the oil pump shaft so the tab on the end of the shaft is vertical
5.oil the new o rings on the housing
6 install new water pump and tighten up
7 position the groove on the water pump shaft vertically so it will align with the tab on the oil pump shaft
8 install the front cover (new gaskets and o rings)
The above came out of my manual.It looks fairly straight forward but watch out for the little o rings they can be a pain. good luck
May 06, 2014 | 1985 Honda GL 1200 Aspencade Gold Wing
I need a user manual for FAIP-1500 Pressure Washer
Is this the one?
http://www.power-washer.us/images/stories/manuals/H150.pdf
Oct 23, 2012 | FAIP 1500 PSI Electric Power Washer
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
Ak38001 admiral washer need to replace drive belt
To change the drive belt you must unplug the washer and lay it forward on its front. Put some cardboard down so not to scratch the paint. Remove the two screws holding the rear panel and remove panel. Undo two bolts holding the pump on. There are three bolts holding the transmission into the washer. Locate the one bolt which has a spacer between the transmission and the post under the transmission. Remove the silver spring at the corner of the transmission. Remove the belt from the large silver pulley.
You will notice the part with the two coils called the wig wag. Under the left coil is a flat shaft. Rotate the large pulley to advance the flat shaft till its as far forward as possible. Insert a large screwdriver into the slot of the flat shaft until it comes out of the vertical shaft that it is inserted into by rotating the pulley with the screwdriver inserted into the slot in the shaft. Drop the vertical shaft till it almost comes out of the slot of the transmission it is inserted into. Tap the gray yoke off the top of the vertical shaft to allow enough room to slide the belt out. Slide the belt from where you removed the transmission bolt and spacer. You should now be able to remove the belt.
Slide the new belt through the space where the bolt and spacer was removed.
Slide the belt through where the vertical shaft was lowered.
Position the belt around all pulleys except the pump pulley.
Reinstall the transmission spacer and bolt.
Reinstall the flat shaft through the vertical round shaft by lining the flat shaft with the slot in the vertical shaft and rotating the large silver pulley until the flat shaft goes all the way through the vertical shaft.
Tap the yoke back into the top of the vertical shaft with the white plastic clip.
Reinstall the spring.
Line the pump pulley behind the belt and make sure the pump activator is positioned into the groove of the flat shaft controlled by the wig wag.
insert the two pump bolts.
You should be ready to go.
Jan 03, 2010 | Admiral Washing Machines
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal kit? Faip 193490.
Alot of people have tried doing this as the genuine o-ring and seal kits are so expensive and sometimes hard to source, but many companies make orings and seals that are unique and cannot be found aftermarket,
If you are lucky you may find some but the only way of doing so would be to take the actual seal and orings down to your local bearing and seal supplier and they will measure it up and do their best to find some for you...
Regards
Brad
Dec 17, 2009 | FAIP Garden
FAIP Vertical Shaft Pump MTPV82684 Logo
49 people viewed this question
Top FAIP Garden Experts
andy just round the...
Level 1 Expert
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Mister Danger
Are you a FAIP Garden Expert? Answer questions, earn points and help others
