Question about RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw
Need replacement bulbs for 21.6V Kawasaki Tools Flash Light
Where can I find a replacement bulb for 21.6V Kawasaki Tools Flash Light
  • Paul Zimmerman Sep 07, 2012
    If you call Alltrade at the 800 number that is listed in the owners manual and right on the tool, they will sell you a 3 pack of 21.6 Krypton bulbs and charge your credit card.
I called customer service and they said that you have to use a Craftsman brand 19.2 volt replacement bulb and it will work.
Posted on Mar 30, 2009
  • spamdump100 May 01, 2011
    I put a Craftsman 19.2 volt bulb in my 21.6 volt Kawasaki flashlight, but it burned out after about one hour of use. I'll try again because I love the flashlight.
Kawasaki cordless drill 21.6 v switch went out after one year of rare use. looking for a switch.
Posted on Jun 04, 2009
If you call the Alltrade.com 800 number listed in the flashlight owners manual and on the tool, they will sell you a 3 pack of 21.6 Volt Kryton bulbs for $15.00, charge your credit card, and ship the bulbs directly to you.
Posted on Sep 07, 2012
1984 kawasaki zn 700a my headlight will not work, tested headlight it works fine with spare battery but will not work when installed in bike. Does the bike have to be running for the light to work?
Hi, Jon if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chafed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/low beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Headlight not working help please
headlight stopped working
http://www.douglasdnn.com/kawasaki/kawasaki-1984-kz-700-workshop-manual.pdf
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Oct 08, 2017 | kawasaki Motorcycles
2011 Ford Escape driver side tail light not working correctly - lights are on but turn signal flash not working and neither is the brighter brake light
I would guess that you need a new bulb. Many of these tail lights actually have two filaments inside them, one that is used for a dimmer light (running light) and one that is used for a brighter light like (brake light, turn signal). The easiest thing to try (and probably the cheapest) would be to buy a replacement bulb and change it. Most places that sell automotive light bulbs will have a large catalog where you look up the make model and year of the car you need a light for and it will tell you which replacement bulb you will need. Then look in your cars manual to see how you access and replace the bulb.
Jan 30, 2015 | 2011 Ford Escape
I have a 1998 kawasaki vulcan 1500 classic. I replaced the center cluster that has the oil pressure, turn signal, and temp warning lights with a aftermaket one. Now my oil pressure and temp light do not...
Check the bulbs, they may be bad, check the voltage to the bulbs when the ignition is turned on. it's pretty simple, they're either getting juice or they're not, if not juice in wires, trace back to find where it's lost at, if you have juice to bulbs, then it one of the two, either the bulbs are bad or you have a bad ground for the bulbs.
May 23, 2017 | 1998 kawasaki VN 1500 Vulcan Classic...
Flash of my Canon PowerShot SD1100 IS not working at all
Has the camera been dropped at all? It may need a new bulb. Most camera stores replace them rather cheap.. But if you want to do it yourself..
How to Replace Your Digital Camera Flash Bulb Like any light bulb, your camera flash bulb can blow at any time. The rest of your camera might be state of the art, but the flash bulb itself is relying on some pretty old fashioned technology. Unlike a light bulb, however, replacing a flash bulb can be a little difficult. Depending on the type of camera or flash you have, some dissection might be required.
Step 1: Choosing the Bulb There are literally dozens of different shapes, sizes and connectors used for camera flash bulbs. These will typically vary depending on the manufacturer. However, be warned, many manufacturers will use different types of bulbs in different cameras. Just because you have a Fuji camera, for example, doesn't mean you can buy any Fuji flash bulb.
Step 2: Safety First Camera manufacturers will never advise you to replace the camera bulb yourself unless you know exactly what you are doing. This is because your camera's flash uses very high voltages. A capacitor will be charged up in order to fire the flash. This capacitor can stay charged for months, if not years. If you're not confident doing this job yourself, then you will need to take it to a camera repair shop.
Sometimes if the camera is too old, you might consider using it as an excuse to upgrade it for a newer model rather than repairing it.
Step 3: Dismantling the Camera Now, you will need to dismantle the camera carefully so that you have access to the flash bulb itself. This may be time consuming and nerve-wracking. One false move could end up breaking the delicate plastic case of your camera.
Once the camera is dismantled, you should then discharge the capacitor safely so that you can continue to work on the camera.
Step 4: Removing the Old Bulb Most bulbs are soldered directly onto the circuit board. In this case, you will need to use a soldering iron to heat up the solder at the back of the bulb and carefully pull it away from the board. This can be difficult, as you need three hands to do it properly. With the old bulb removed, try to clean up the solder pads as much as possible so that the new bulb can fit properly.
Step 5: Replacing the Bulb Push the legs of the replacement flash bulb in position through the holes in the circuit board. Then, using a soldering iron and some solder, fix it in place. Be as accurate as possible to prevent shorting out the circuit. With the bulb in place, cut back the legs of the flash bulb so that it doesn't stick out too far from the board.
Step 6: Reassembly With the replacement flash bulb fitted in the digital camera, you will then need to reassemble your camera. This will be easier if you kept all of the screws in a safe place.This is the one occasion where it's a good idea to assemble before testing simply because of the high voltages involved.
Step 7: Testing Now, put the battery back in the battery and try taking a photo with the flash. Check whether it works; if not, you will need to investigate the cause of the problem
Nov 03, 2010 | Canon PowerShot SD1100 IS Digital Camera
Easyshare Z8612 IS Digital Camera: My flash bulb has blown and I need to know how to ...
May 17, 2010 | Kodak Easyshare Z8612 IS Digital Camera
Have installed led indicators to kawasaki zx6 2004 model now flash rate too fast
Flashing too fast indicates too much current flowing and this would point to a bad bulb or shorted socket. Maybe a grounded wire in the circuit. Check these items with a DVM....
Feb 21, 2010 | 2004 kawasaki ZX-6R
How to replace bulb in flash for a Kodak z710
Dec 31, 2009 | Cameras
Replacement Bulb For Kawasaki 19.2 Flashlight
   May I suggest taking the unit to where you purchased it and see what they say? Alph of Spokane WA.
Oct 11, 2007 | kawasaki 19.2V 4 Piece Cordless Tool Kit
RTO 21.6v Kawasaki 4 Piece Cordless Power Tools Drill Saw Logo
1,904 people viewed this question
Top RTO Drills Experts
Are you a RTO Drill Expert? Answer questions, earn points and help others
