Question about Gentron 3500 Watt Propane Generator PRO2-3500P
Gentron 3500 Watt Propane Generator will not start
Have spark, Fuel at carburetor, "puff" upon cranking with plug out.
3 Suggested Answers
  • 6468 Answers
SOURCE: Gentron 10000w portable generator w/electric start cranks but wont start
check for low oil some have a low oil shut off system
Posted on Oct 15, 2012
SOURCE: gentron pro2 6000p has no spark
With small engines, ignition is magneto. Four things can cause a lack of spark: (1) Faulty plug - try a new plug; (2) Bad, shorting, or disconnected spark plug wire - check for high voltage from ignition coil; (3) Bad ignition coil - check for low voltage at the coil input wires; (4) Magneto failure - the pickup coils next to the flywheel may be shorted, loose, or disconnected, OR the magnets on the flywheel may have lost their field or come out. I would troubleshoot this problem by checking and eliminating each of these possibilities in the above order. If all of the first three check out good; I'd have a mechanic check the magneto because this requires at least partial disassembly of the motor.
Posted on Nov 17, 2012
Gentron 10,000 generator will not start.
Spray starting fluid into the engine air intake and see if that starts it, if that does then you have dried fuel clogging up the works.
Nov 21, 2016 | Gentron Electrical Supplies
Where can I get an owners manual ?
PDF]10000W Generator
scene7.samsclub.com/is/content/.../GG10020-Eng%20manual-cpdf
Gentron/UPC will repair or replace, at Gentron/UPC's sole option, products or components ... Expendable parts or accessories supplied with the product which are..... FILLED WITH OIL OF A HIGH QUALITY SAE 10W-30 GRADE ENGINE OIL.
Gentron - 10000 Watt Gas Generator with Electric Start
www.samsclub.com > Sam's Club > Emergency Supplies
Sam's Club
Rating: 4.4 - ‎330 reviews
Gentron 8,000W / 10,000W Portable Gas Powered Generator with Electric Start ...... 1 year parts and labor limited manufacturer's warranty; For issues not ...
Gentron Pro2 10000w Gas Generator (GG10020)
https://generatornow.com/gentron-gg10020-pro2-10000w-gas-powered-...
Gentron GG10020 Pro2 10000w Gas Powered Portable Generator with Electric ... It's a one year/1000 hr parts and labor warranty for our residential customers.
Jan 21, 2016 | Electrical Supplies
Why porter cable h450is generator won't start
If it starts initially, then it has spark. most likely the jets on the carbureator are clogged. You should remove the carb and clean/rebuild it.
Sep 07, 2014 | Porter Cable 4,500 Watt 9 Hp Portable...
Gentron gg10020 carburetor
Float probably stuck. Remove and rebuild the carb.
Sep 06, 2014 | Gentron 10,000 Watt Gas Generator GG10020...
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
Dec 03, 2013 | Gentron 10,000W Generator with Electric...
Generator will crank but will not start
First check spark while cranking over( pull the plug wire hold by insulator about a 1/4 inch away from any ground, you should see a strong spark. then check to be sure the fuel is pumping from yhe carb., if no fuel try a short squirt into the carb intake. should fire up if you had spark.Its generally a good idea to put in a new plug and be sure to check the gap.
Oct 01, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
Fuel switch needs to be replaced does not shut off fuel intake
How did you stop it? Pull the spark plug wire?
There is a carburetor in there,somewhere.Pinch off the fuel line to or from the carb. I like needle nosed vice grips or a BIG hemostat.
Feb 21, 2013 | Champion 3500/4000 Watt Portable Generator
Gentron pro2 6000p has no spark
Nov 17, 2012 | Gentron 6000 Watt Propane Generator with...
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
Yg2800i generator runs for about 5 minutes and then stalls
Put a new fuel filter on it and when it stalls take the fuel line off the carburetor to check if gas is getting to the carburetor. If it is remove the sparkplug put the wire on it and ground the nut of the plug on the engine block and pull the cord and check for spark between the sparkplug gap. If no spark you might have a faulty coil, when it gets hot it has no spark.
Mar 20, 2011 | Yamaha 2500 Watt Industrial Inverter...
Gentron 3500 Watt Propane Generator PRO2-3500P Logo
55 people viewed this question
Top Gentron Electrical Supplies Experts
Phil Walker
Phil Walker
Adam Plug
Adam Plug
M.R.
M.R.
Level 1 Expert
Are you a Gentron Electrical Supply Expert? Answer questions, earn points and help others
