Question about Samsung Microwave Ovens
Samsung microwave model smh1951w the door wont stay latched anymore is this repairable? and how?
The door suddenly stopped latching and will not stay shut now. there were no warning signs of a coming malfunction, it just stopped. is this repairable? and where would I find some sort of tear down instructions? Lol I cant find anyway to disassemble the door to look at the latch, there isnt a single screw showing holding the door together.
MicrowaveSvc
  • 9047 Answers
SOURCE: Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Posted on Nov 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Door Disassembly
Actually, the spring is probably okay. What breaks is either the latch head (with the hook-like protrusions) OR the spring mounting tab on the inner side of the outer door panel. The spring connects to both of these parts. The outer door panel is not availablke as a separate part, so if that's where the break is, you'll have to get a bit creative and clean it squeaky and use epoxy (like JB Weld, but never use "super glue") or you can drill into the panel slightly and install a small screw eye or glue it in place. Even if the spring mount on the inner door panel is not yet broken, while you're in there, it's a good idea to clean it squeaky and add some epoxy to strengthen it. To get to the screws, you have to remove the choke cover (see sample photo below). It's usually not necessary and is better not to remove the door. You can set the oven on its left side on a table top, open the door carefully, and ease it down to the table top. Then you have a level, stable area to work on the door. If the problem is the latch head (ref # 5-2-2) then I would recommend replacing that part instead of gluing it. That's because the new part may be an improved version. Plus you'll start out fresh. The part # is LSTPPB030MRF0 (zero on the end, not an "oh") You can order Sharp parts from http://wwww.wehaveparts.com You can find a helpful exploded view of the door here: http://207.234.249.73/mwd/r1480_control_door_exp.pdf
Posted on May 11, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: the door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Sep 23, 2007
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
Why door will not stay closed
Latch or catch is either broken or misaligned. Find out which and repair or replace.
Aug 10, 2014 | Samsung SMH1816S Stainless Steel...
Sharp microwave R-520K/R-520L door wont stay closed how can I repair it
There is a tension spring pulling the door latch assembly in a downward direction, keeping the door latch closed against the door switches and latch.
Spares required will be either a spring or a latch assembly both fitted inside the door. To get to them the plastic choke cover around the perrimitter of the inside of the door must be removed to reveal fixing screws.
eSpares Spare Parts Accessories for Electrical Appliances eSpares
Oct 31, 2017 | Microwave Ovens
How do you remove the door panels on a samsung SMH9187ST? I am replacing / repairing the door latch.
Hi Jerry, it sounds like I have the same problem as you. Have you been able to fix yours?
Sep 08, 2012 | Samsung SMH9187ST Microwave Oven
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
Dometic door on convection microwave wont stay closed
Damaged or bent latch/s---unit would have to be taken apart to see if fixable or needs parts replaced.
I would Google the full model number with "parts" to see what is available for this unit.
Jun 15, 2012 | Microwave Ovens
SAMSUNG MICROWAVE, MODEL SMH9187ST, WHEN NOT IN USE, WE HEARD A SMALL NOISE (CLICK) AND THE DOOR OPENED. THE DOOR WIL NOT LATCH AND STAY CLOSED. I CHECKED THE TWO FUSES, THEY ARE GOOD. WITH THE...
Hi dschema,
You have a door switch issue. There are three behind the panel. If you can lift and hold the door and it starts one of them is bad for sure. You would be better off replacing all three or have a repair man replace them because a microwave can hold 3000v even unplugged.
Hope it helps.
Thank you for using FixYa.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
It may be the latch head spring or the door open lever or button.
DOOR SPRING LATCH HEAD HOOK
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
DOOR OPENING BUTTON LEVER
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
The best place to order Sharp parts is
Encompass (formerly Tritronics).
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Oct 10, 2009 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
