Question about Home Security
How do you change the battery in a HPM 645/3 smoke detector?
3 Suggested Answers
  • 5 Answers
SOURCE: How to change the battery in my SCO5RVA smoke and
Not obvious, and th emanual is not too precise about this as you probably know.
What I did on mine: take it off its bracket, flip it over bottoms up. You will see a part of the "rim" curving slightly out, that's the battery cover lid.
It is a very tight fit; to make things relatively easy, rotate the unit with the bottom still facing up until the curved part is on the right of the unit. Make sure there is no (red, if I remember correctly) peg locking the compartment closed, then insert your right thumb in there, and pull out. The battery compartment will eventually slide out part of the way. Remove the battery by pushing them out from below the battery compartment; they are on two separate blades that can be used to push them out.
Shoudl do the trické
Posted on Aug 07, 2010
joeguest2
  • 2080 Answers
SOURCE: smoke detectors keep saying low
Occasionally these units can malfunction due to a buildup of dust inside which can interfere with the smoke sensor. Try opening the cover to the smoke alarm and vacuuming out the dust, or better yet, get yourself one of those cans of compressed air that are used for cleaning computer keyboards and thoroughly blow out all the dust.
Just to be certain, you can always test the new battery with a voltmeter to ensure it is in good condition before you put it in the detector. If you buy the really cheap brands of batteries, you will sometimes get one that is dead right out of the package.
Once you have inserted a good battery, try activating the smoke alarm using the TEST button.
If the smoke alarm continues to beep unnecessarily, then it is likely an internal fault and it's simply time to replace the unit with a brand new one.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe
Posted on Aug 04, 2011
MY ALARM KEEPS CHIRPING. Thought I should change the battery but discovered it's not battery operated!
A chirping smoke detector indicates low battery! Change battery or replace smoke detector!
Aug 15, 2015 | Home
Locate battery on kidde home smoke detector to change battery ?
Kidde Dual Sensor Battery Operated Smoke Alarm PI9010
25436074-0u3vpaqtlkylcnuyowrcgmo2-1-0.jpg reference: http://www.kidde.com/home-safety/en/us/products/fire-safety/smoke-alarms/pi9010/
Feb 16, 2015 | Home
What causes continual beeping
With some smoke detectors, this indicates a low battery. Try putting in a new battery and see whether it stops beeping. If it doesn't add a comment to this question and specify the make and model of your smoke detector.
Oct 06, 2014 | Home
Nortron smoke detector
It may be urging you to change the battery...
May 09, 2014 | Home
Every hour my detector beeps and the green lights flashing is it carbon nonoxide or smoke or battery??
If it only beeps once and then pauses, the batteries are suspect. The batteries should be replaced twice each year. I like to change them when we change the clocks back and forth.
I hope that this helps.
asnowman
Hint you can test them with a match (blow it out) and let the smoke rise into the detector. I recommend that this be done at lease once a year.
Hope this helps
asnowman
Apr 17, 2010 | First Alert SA302 Dual System Smoke...
Kidde smoke alarm won't stop chirping . I have replaced the batteries and nothing seems to fix the problem
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Mar 21, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Jan 28, 2010 | Kidde i12040 Hardwire Smoke Alarm with...
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
Home Security Logo
2,339 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
