Question about Hayward Industrial Products Hayward EcoStar Variable Speed Pump SP3400VSP
Have power to pump, but pump won't run
Eco Star Variable Speed Pump Model SP3400VSP
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
I live in NC and have chosen NOT to close my ingroud pool. I leave my variable speed pump running continuously at a low speed. I'm worried about extended cold weather below freezing. Will incr
Even at low speed these pump move allot of water, I would feel better with the pump running on high. but most variable speed motors only run on high for a few hours and return to low speed. If you cant force the motor to run on high continuously, IF YOU can't run it on high= The wind chill is the concern, might I suggest covering the plumbing portion with a tarp, just do not cover the motor it needs air to cool the motor.
A $10 hot water heater blanket Google Search might work on your filter,and some plumbing insulation tape Google Search OR if it gets real cold you could build a temporary pump house out of say 2'' PVC and with 8 or more Concrete Blocks and some tie down straps to secure it down and cover the whole works with a tarp using some of the blocks to hold the tarp in place, this way the heat from the motor will keep it nice and warm inside your temporary pump shed, but this is only if you can't run the motor on HIGH continuously, low speed worries me with possible - minus 40 Degree temps.
also turn the pools jets up to keep the pools water from freezing up and turning into a skating rink.
IF you have a pump that only runs on high for a few hours you will need to set your alarm clock and get up and reset the pump to run on high again, just to be safe.
The pump creates heat by act of pumping water, so you have that on your side. ..keep us informed on your results as these variable speed pumps are fairly new to the market.
thanks .. Jay
Jan 07, 2015 | Pool & Spa
I have a Hayward sp3400vsp. The pump runs all night some times, the screen say is priming, it will shot off manually, and it wont do it all the time. help??
Sounds like the pump is sensing that there is a problem with water flow on the suction side.
Could be caused by air being sucked into the system. Do you notice air in the strainer chamber? Or bubbles coming from the inlets in the pool?
Could also be caused by something clogging or restricting the suction line.
May 31, 2014 | Hayward Industrial Products Hayward...
Will not stay running
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
2007 Star 1100 won stay running Yamaha Forum Your Yamaha Motor Products...
2007 Star 1100 won stay running AR15 COM
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Mar 12, 2014 | Yamaha V Star 1100 Classic Motorcycles
I have a Hayward sp3400vsp 2 HP pump for my in ground pool.When I turn on the pump it tries to auto prime for about 5 minutes and then shuts off. The pump is less than one year old. Any susgestions?
I have the same model pump. When I had it put in, the installer said that the auto prime function had some bugs in the software. He suggested changing the setting to 3 minute prime. You can change it in the configuration menu. I assume that your pump is actually priming and not running dry. Hope that helps. Please reply if you need more help. Good luck!
May 03, 2013 | Pool & Spa
Pump will not run, electronics operate well
Can you plug the pump in directly to power and run it full speed? As this is an old problem, I'm sure you have already fixed it.
Oct 07, 2012 | Hayward Pool Products Hayward EcoStar...
Our pool pump won't hold pressure
make sure all unions are tight
Aug 21, 2012 | Pentair Pool & Spa
My new ecotouch pump will not pump. It is a week old and the problem has occurred today. The lights on the pump indicate that it has power, there are no error flashes, but the pump does not switch on. When...
I would check the correct voltage is being fed to the pump (220-230v). Otherwise call this guy at the company, he was pretty helpful to me. Remember you have a 2yr warranty.
Ed
Chris Calise ? Manager - Pool Sales
Speck Pumps ? 8125 Bayberry Road Jacksonville, FL 32256
Phone: 904-739-2626 ' Fax: 904-737-5261
Toll Free: 800-BADUJET (2238538)
Email: c.calise@speck-pumps.com
Jul 02, 2011 | Speck Pumps Badu Ecom3 Variable Speed Pool...
Hayward Industrial Products Hayward EcoStar Variable Speed Pump SP3400VSP Logo
43 people viewed this question
Top Hayward Industrial Products Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Hayward Industrial Products Pool and Spa Expert? Answer questions, earn points and help others
