Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution » Compaq Laptop's Solution » Acer Laptop's Solution » Dell Laptop's Solution » Toshiba Laptop's Solution » Asus Laptop's Solution » Gateway Laptop's Solution » IBM Laptop's Solution Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download » Compaq Driver's Download » Acer Driver's Download » Dell Driver's Download » Toshiba Driver's Download » Asus Driver's Download » Gateway Driver's Download » IBM Driver's Download ami-35Here is some great source to solve any kinds of laptop's problem.
Save your data asap and replace the drive it's failing. All drives fail over time you are lucky in that you are getting a notice. Others are not as fortunate.
This indicates that your computer is configured to boot on the floppy drive. 1. At the start of the computer Press F2 2. Go to the Boot Device Configuration. 3. Enable Hard Disk Boot Priority. 4. Set the First Boot Priority to Hard Disk 5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Sounds liek your hard drive has failed, search ebay for this model of laptop with hardrive at end of yoru search, not 100 percent sure but im nearly 90 percent sure its hard drive failure.
Any system can be recovered, although it depends on what is wrong.. this error can mean no info on the hard disk, or damaged hd...more than likely whoever had the computer erased it for data's sake...I would've...get an os and load it.
Bad sectors on a hard disk is an every day thing, the hard drive keeps a bunch of spare sectors and a table to reroute bad sectors to the backups. This warning basically means that you are out of backups, and now you may start losing real data if you do not change the hard disk.
your hard disk is bad...just try to reinstall the windows
