Question about Toshiba Satellite Pro 6000 Notebook
I forgot my password on my toshiba pro6000 f1 dont work and cant get in to the bios and i have tried looking for the cmos batt but cant find it plezzz help
  • cosmicstevo Mar 16, 2009
    do i have to touch the jumper pin as well as takeing the cmos battery and if so where is the jumper pin's to thanks for the help
  • 211 Answers
And look here how to dismantle:
http://www.irisvista.com/tech/laptops/Toshiba6100/Toshiba_Satellite_Pro6100_dismantle_1.htm
Posted on Mar 11, 2009
  • aliokas Mar 16, 2009
    You don't have to. Just disconnect batter, cmos battery and main, then press and hold power button for 20s. Connect everything back and turn on.
I forgot BIOS Password
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them for Bios Password or Bios Password Reset.
I searched and Toshiba did not have any manuals or drivers for this model. Must be really old.
Anyway try the link below for removing the bios password.
http://www.ehow.com/how_6795884_reset-toshiba-tecra-bios-password.html
You could try removing the cmos battery.
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.
May 22, 2012 | Computers & Internet
This is my problem my 12yearold son thought it would be cute to put a bios password on a toshiba satellite 1415-s105 and forgot the password need to remove the password and I already tried removing the...
You may be able to remove the BIOS password using a parallel plug.
This WEB site describes the procedure for such a plug and how to bypass this BIOS password.
http://www.laptoprepair101.com/laptop/2006/02/10/remove-clear-toshiba-laptop-bios/
Jul 16, 2011 | Toshiba Computers & Internet
My 12yearold son thought it would be cute to put a bios password on a toshiba satellite 1415-s105 and forgot the password need to remove the password and I already tried removing the main batt and the...
I believe you have done a battery discharge way but is still not working. There are software that can actually do the reset or even remove the password on the BIOS. Also, please try the below
With the battery in, find the CMOS jumper. There should be two pins connected with a jumper(lets named it Pin 1 and Pin ) and there should be pins that is free (lets call it Pin 3). Let say Pin 1, 2, and 3. You need to take off that jumper and moved it to pin2 and pin3 for few seconds and then reinstall it back to Pin1 and Pin2.
CMOS password should be now reset.
Jul 15, 2011 | Computers & Internet
Cant find cmos battery on toshiba satelite l300 motherboard, need to reset hdd password
You cannot reset a HDD password (if its a bitlocker one) and you have lost your encryption key reset file and forgot password.
if you mean the BIOS/Power on password then try this
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 10, 2011 | Toshiba Satellite Pro L300 Notebook
When ever i power up my toshiba satellite laptop,there are two blank screens with a blue box in the centre saying enter password
the bios passowere has been engaged go to bios by pressinfg del or F1 button on startup go to bios setting password you will see enter password press button with passord blank again it will ask for confirm password enter blank password press enter it will delete all the password if you are un able to enter bios and asking for password remove the cover you will see three jumber pins near ur cmos battery pin one and towo are for normal pin 2 and 3 for clear comos in some there are only 2 pin short the pin to clear the cmos some times shorting doest start the computer dont worry put the jumbers back to the normal position and restart the computer while stating you will see cmos reset press F1 to continue or press DEL to enter bios press DEL and enter the correct time as clearing the cmos the time will be set defult if you cant see cmos jumper pin remove the cmos battery and restrt the computer then shut down the computer and place back the cmos battery in its compartment doing this please remove the power to your hard disk or your haRD DISK MAY GET CORROUPTED
Oct 24, 2010 | Computers & Internet
I am working on a toshiba satellite l355-s7915. the owner's kid forgot her password, so I tried to remove the password with hirens active password changer, which failed. when I started up the computer, it...
Yes of course all Laptop and Desktop have CMOS battery. Screw the back cover of your laptop locate the CMOS battery and remove to clear the BIOS password. Or else you can reset the CMOS by removing the jamper.
Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
Forgot password fot toshiba satellite m45-s169
Thats a Power On Password...I believe the only way that you can get around/reset/disable it...is by taking out the battery out of the Cmos. I will be looking for more ways other then that but thats one that i know works...
If you would like to attempt it...i dont recommend it for the no computer people...look up fourms and see if others have had the same problem or if people have taken the computer apart and replaced the cmos battery
Dec 12, 2009 | Toshiba Satellite M45-S165 Notebook
I need to clear he bios password in a toshiba satellite pro L40
  1. Remove battery.
  2. Remove memory.
  3. look at the side of the memory at the top left side and locate the little brassy coloured dots with the lettering JRST1 at the side (jumper reset 1).
  4. Touch something metal across them for a few seconds.
  5. thank me because no where on this stupid internet has anyone got a solution to this and I had to find it out on myself.
Good luck, Bowling Crony.
Sep 08, 2009 | Computers & Internet
Toshiba Protege 2000 Lost BIOS Password
if you are getting password in the booting of the pc then it is bios password plz check the link
http://www.tech-faq.com/reset-bios-password.shtml
if it is not then try to boot in the safe mode and change the password
Jun 24, 2008 | Computers & Internet
Help clear bios
When you remove the battery from the motherboard wait after few seconds (30), reboot your computer without the battery and press the BIOS key (F1 or F10 or DELL key) will not ask you any password. Turn it off and Then put back the battery.
May 21, 2007 | HP (D5680-60001) Motherboard
Toshiba Satellite Pro 6000 Notebook Logo
308 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
