Question about Garden
I'm looking for a toro timecutter z480 drive belt diagram
I need put a new drive belt on and need a diagram to see how to do this.
jgwhomeequip
  • 1902 Answers
SOURCE: toro timecutter spits and sputters when blades are engaged
Did you drain the fuel before you put it away? If not then you should drain the fuel and clean the carb. Gas when in lawn mowers and any other small gas engine will turn into a slim in a way and will block the carb. Drain the fuel and clean the carb system will run great when that is done
Posted on Feb 19, 2009
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
  • 246 Answers
SOURCE: bought a 2002 toro timecutter 18-52 zero turn lawn
Hello:
>>You can View a Breakdown/IPL of the Mower at this Site Addy, https://lookup3.toro.com/partdex/default.cfm and Select Start Parts Viewer. Now Enter the Model Numbers () and Click Search. Now Select View Assembly Drawings for your Year Model.
At the Bottom of the Page (#6), Use this Link to Locate your Local Toro Dealer who can Order the Manual for you or you can Contact Toro Using the Options at this Site Addy; http://www.toro.com/contact/Homeowner.html .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 3 Answers
SOURCE: drive belt popped off by limb i ran over need drive belt diagram
I've got a manual. Can I fax to you copy of diagram? Send your info to my fax no. 209-394-0868.
Posted on May 12, 2009
SOURCE: need diagram or instructions on putting on new cutting belt
bex bissell proheat
Posted on May 21, 2009
How to check hydraulics on toro timecutter z480
check the fliud level and chang filter and hydro fluid this might let it start working again if dont look at buy new hydrstatic pump about 200 hundred dollars pump goes bad if oil is dirty or if low on fluid
Aug 25, 2014 | Garden
What's wrong, No hydraulics on toro timecutter z480?
answered prevoisly look at buying new pump
Aug 25, 2014 | Toro Garden
How do I replace an idler pulley on mower deck on toro timecutter mx 5060?
Release belt tension, unbolt the pulley, replace it with a new idler pulley. If you need more help, please follow up here.
Jul 29, 2014 | Toro Zero Turn TimeCutter MX Series MX4260...
How do I replace a Toro mx5060 drive belt?
First, jack up rear end and support with jacks and ramps. When u first look you will see the first step is to drop the blade belt. Next reach up around the main drive pulley and disconnect the wiring plug by popping up the latch. It may be a tight fit for someone with big hands. Next you will need to separate the stabling plate and move to the side. You will need to remove the tension spring to loosen your small tension pulley. You should inspect your pullies for wear, I had to replace them too, especially the plastic one. You can now apply your new drive belt. Make sure you apply the belt properly or it will just chew up the new belt. It took me two belts to figure that out. You can download a diagram at toro.com. Re-apply your tension and replace all parts in the order you took them off, making sure the wiring adapter is securely in place. Try and start the more and check belt observing safety rules.
Jun 21, 2014 | Toro TimeCutter MX5060 50" 23HP Lawn Mower...
How to reinstall the main drive belt on a Toro Timecutter 42" zero turn mower.
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual..
Apr 28, 2011 | Toro Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
