Question about Ac Delco Car Audio & Video
Where do wires go from the 9 pin on delco model # 09383075
Where do wires go to from the 9 pin on delco model # 09383075
3 Suggested Answers
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
jerry_kramer
  • 3904 Answers
SOURCE: Wiring diagram for 24 pin and 12 pin connectors on delco radio part number 10338745 came from a 2003 Buick
Surprisingly free resource is the library on this. They do have a lot of the automotive manuals you can check out. The other place is Barnes and Noble. Sometimes they have the older books "not sealed" for you to browse through.
Posted on Dec 20, 2015
How do I find the Wire diagram for Delco Stereos?
If your nice to the dealer concerned they might help you with a diagram.eg what ever make car it came out in.just a suggestion.
Aug 14, 2014 | Ac Delco AM-FM Radio Cassette
Hello......can anybody give any solution for this problem : my VGA Cable disconnect from the 15 Pin gents connector of Crt monitor of philips model no. 107E61 I want to fix it but I could not understand...
These connectors come with 15 pins and 9 pins. But be carefull, the nine pin connecter uses a tottaly different color code. Thats for an oldschool gamepoort or midi connector. But I think the vga connector has 3 rows of pins total of 15. But the nine pin connector has probably two rowes of pins. And thats no vga connector, but an connector for an serial port.
If it has three rowes (see Fig-2 below) but uses 9 pins then its an RGB instead of VGA.
Fig-1
Fig-2
Fig-3
Mar 19, 2017 | Cars & Trucks
Creative 9 pin male din damaged
The only way to go is Replace the 9 pin adapter. Radio Shack may have the adapter, check them out. You will need to be observant when locating the proper colored wire corresponding with each pin. Two ways to do this and all require a soldering iron. Either split or open the cover on the 9 pin male adapter and expose the wires going to each pin. Identify the colors and pin numbers and draw a diagram on paper to keep for reattaching the wires later on. Cut 1/4 of the insulation back from the end of each wire and tin the wires. In short, hold the solder to the wire ends and heat with the iron so a flow of solder runs along the bare wire. Make certain to put a connector cover onto the wires prior to soldering each wire in place on the pin end. Simply set the correct colored wire end in the proper pin number, hold the iron to the pin back end and allow the wire to affix itself. Do this with all wires. If you do not have 9 wires, that is not unusual, just do the procedure with what wires are available. If you cannot get the outer jacket off of the current 9 pin connecter, then you will need a Volt/Amp meter. Here you simply cut the wire approximately 1/2 to 2/4 Inch back from the cable 9 pin adapter, and locate the pin that corresponds to the colored wire. Using the RESISTANCE part of a meter, when you touch the two probes together the needle moves on the scale. Touch one end to a pin and try each colored wire end until you see the movement on the scale. Now you know what color corresponds with each pin. Solder each colored wire as mentioned above.
Dec 15, 2013 | Creative Technology SBS A200 2 Speakers
Need wiring diagram for delco car stereo model 16165893
I know how to wire it but it only show AM....it is not an FM radio?
Mar 16, 2012 | Ac Delco AM-FM Radio Cassette
I have Delco Model 2J2424r1, frame 56R, Series A84, phase 3 electric motor. What is the wiring diagram to run it under 230VAC?
If it has 9 leads and is a 240/480 volt motor the 1and 7 go to line 1. the 2 and 8 leads go to line 2 and the 3 and 9 leads go to line 3. the 4 5 and 6 leads are hooked together with a wire nut. To reverse rotation simply reverse any 2 of the line leads.. Prairie Dog........
Jun 15, 2011 | Leeson Reversible Electric Motor 3/4 HP
Motherboard manual To connect main wires
Usually indications are printed beside proper connection Pins . Find your model number and posta comment to look for your motherboard data sheet on web.
Sep 17, 2008 | Intel Motherboard
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Car Audio & Video Logo
48 people viewed this question
Top Ac Delco Car Audio & Video Experts
MarcellusA
Level 1 Expert
Are you an Ac Delco Car Audio and Video Expert? Answer questions, earn points and help others
