Question about Fedders Appliance Air Conditioner In-Window
How much gass reqired in 1.5 ton ac r22
HOW MUCH KG REQUIRED
  • 31 Answers
To many variables here to say. Pipe length, compressor size, acumulator, receiver etc. R22 very expensive here maybe not where you are.
Posted on Apr 23, 2013
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
WHAT IS REFRIGERANT SUCTION PRESSURE OF MY 1 TON SPLIT AC?
R22= 70-80psig
R410a=120-130psig
Depending on many variables such as blower speed, coils clean, indoor/outdoor temps.
Aug 05, 2015 | AMVENT 18000 Btu 1.5 Ton Ductless Mini...
Have a bryant 3.5 ton outside can I change to a bryant 4.0 ton and still use the same inside equipment
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier. Hope this helps.
Jan 28, 2013 | Bryant 3.5 Ton R22 12 Seer Condenser Only/...
How many pounds of R22 is requried in 7.5 ton or 15 Ton AC unit.
it all depends on how long the lines from the compressor to the evaporator are the label on the condenser unit should give you a ball park figure
Jun 01, 2011 | Refrigerators
Calculate 40 metric tons of diesel oil to gallons
Hello, i did the math for you..
1000 KG = one metric ton.
1 litre = 0.264172052 Gallons.
1 litre of diesel = 0.832 kg/l (density)
You need 40,000 litres of diesel in gallons,
so 40,000 KG/0.832 kg/l (KG/L) = 48,076.9231 litres.
so total gallons is 12,700.5794 US gallons.
Hope it did not confuse you and it helped you.
Thanks please rate if you got your answer
Feb 22, 2011 | Computers & Internet
1mmt=?kilogram
I assume by mmt you refer to MMT (Million Metric Tons).
1 MT (metric ton) is 1,000 kg
1 MMT = 1,000,000 x 1 MT = 1,000,000 x 1,000 kg = 1,000,000,000 kg
Feb 12, 2011 | Office Equipment & Supplies
Fedders Appliance Air Conditioner In-Window Logo
202 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
