Question about Brother PS-1250 Pacesetter
How do I thread sewing machine
Can't remember how to thread the machine and I can't find my owners manual
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Brother Master
  • 102,366 Answers
You may access the manual here.
Posted on Apr 20, 2013
  • 10 Answers
SOURCE: HOW DO i THREAD A BROTHER BM2600 SEWING MACHINE
They have several brother diagrams and threading instructions @ http://www.sewusa.com. I hope this helps you.
Posted on Jul 24, 2008
  • 323 Answers
SOURCE: how do i refill a bobbin 7 thread machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To wind a bobbin, guide the thread from the spool post to the small round tensioner /guide on the top of the machine.Wind a few turns of thread onton the bobbin.Place the bobbin on the bobbin winder post. Release the hand wheel and wind the bobbin as full as you like or until it stops. Remove the bobbin,place it in the bobbin case and insert the bobbincase into the hook.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Posted on Apr 30, 2009
  • 5 Answers
SOURCE: brother mark 3 DB2-B755-3A operating owner manual.
I have the manual here.....
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
Posted on May 29, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
Jimsta01
  • 405 Answers
SOURCE: How to thread a Brother cs-100 sewing machine
Please follow the link below, for the manual
http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000207/cs100ex660qg01enfres.pdf
Posted on Mar 30, 2010
Where are the oiling points and what would make the threads constantly break
Depends on your make & model machine. Newer computerized machines require little or no oiling. Consult your owner's manual AND use only good quality sewing machine oil.
Thread breakage:
#1--Avoid bargain bin variety and old thread!
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Apr 07, 2017 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
How do I use the thread cutter?
Most of the time, you will sew a seam and then do a few stitches after pressing the Reverse button. Leave the presser foot down and press the button with the scissor icon. (That's the top-most button in the row that curves up from the needle area.) The LED will blink. If the thread cutter LED blinks when you turn on the sewing machine, press the button again. The machine will remember if the thread cutter was in use when the power went off. For some thick threads, the auto-thread cutter will not work. Instead you'll need to lift the presser foot and bring the item up to the thread cutter on the side of the sewing machine. It's towards the back of the side of the sewing machine near the needle.
You can even program in the thread cutter in memorized sewing pattern by selecting pattern 48 and pressing the M button after all the other stitches for the pattern are added to the program.
Do remember to clean the thread cutter regularly. Lint or thread buildup will interfere with the mechanism. The cleaning steps are on page 61 of the manual.
Janome has the instruction book for the Memory Craft 6300P on the product page: http://janome.com/en/machines/sewing/6300p/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/professional-series/inst-book-6300peng-fr-sp.pdf .
I hope this helps.
Oct 22, 2015 | Janome MC-6300P Heavy-Duty Computerized...
How to thread a jones M 684 sewing machine
I've looked at the internet for a manual & can't find one
here's what I suggest,, go to the sites listed below & email them
asking them about a manual or threading instructions
sewvacdoctor.com
a1sewingmachines.com
Aug 21, 2012 | Sewing Machines
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Have a White Rotary Sewing Machine Serial number FR2701777. What model is it?
check with these sites about a manual & needles,,you'll need
to email them the name & serial number & ask them, they should
be able to help you
sewusa.com
sewvacdoctor.com
Aug 03, 2012 | White Sewing Sewing Machines
How do you thread a bernina 1080? My mom can't find her manual
sewusa.com has some threading diagrams,but I'm not sure they'll have
the one you need
Jun 08, 2012 | Sewing Machines
How do I thread the Riccar RM 540
sewusa.com has threading diagrams
or go to the riccar website & enter the site & in the search box at the bottom put in manuals & then on the page to the left look for the product manuals & then go to sewing machine owner manuals & look for model number RM 540,,,it is there
Dec 03, 2010 | Riccar Sewing Machines
Owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Jan 25, 2009 | Janome Mini Compact
Sewing Machines Logo
64 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
