Question about Furniture
My silhouette making clicking sound in the back sound my doors locking over and over
1998 silhouette
SOURCE: 1998 Toyota Corolla Electric Door Lock Problem
You'll need to replace the solenoid (motor) that doesn't work. Not hard once you get the door panel off. I suggest you buy the correct part, not a universal one.
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: 2006 BMW 323i Passnger Door lock will not lock / unlock w/ remote
Replace fuse 57 (15 amp) then disconnect battery and wait 30 to 45 minutes before reconnecting the battery.
My 2006 BMW 325I had the same problem with the door locks not responding. I checked all related fuses and found #57 (15 amp) was the only related fuse blown. I put in a new fuse and it still would not work. I then disconnected the battery for a while then once I reconnected the battery everything worked fine.
I believe I blew the fuse while repeatedly pushing the unlock button rapidly while walking across the parking lock to the car. I suggest only pushing the unlock button only once or twice.
Posted on Dec 11, 2009
ercupa190
  • 12223 Answers
SOURCE: my 1998 Silhouette back door won't unlock with key or fob
follow the steps and fix it. God bless you
    • 1 Enter the passenger side of the vehicle and look under the dashboard, beneath the glove box and near the floor mat. With the aid of a flashlight, locate a large panel, which is held in place by screws. Unscrew the panel manually or use a screwdriver if the screws are too tight.
    • 2 Locate the fuse panel. The panel houses long rows of fuses mounted to the panel. Consult the vehicle's owner manual to determine which of the fuses controls the automatic doors
    • 3 Remove the fuse that controls the automatic doors with a pair of fuse pliers, or carefully with a pair of regular pliers. Examine the fuse by shining the flashlight close against it. If the metal bar inside the fuse is broken, the fuse has been blown.
    • 4 Replace the blown fuse with a fuse of equal amperage. Push the new fuse in place, confirming it is a snug fit.
    • 5 Test the automatic doors before screwing the fuse panel cover back in place. If the doors close automatically after you manually give them a tug, the problem was the blown fuse. Replace the fuse panel cover under the glove box.
    • 6 Test the automatic doors with your remote control. If they do not open or close, the problem is with the remote. Pop the rear cover off of the remote with a screwdriver and replace the battery.
Posted on Oct 18, 2012
steve_luck12
  • 817 Answers
SOURCE: central locking making loud clicking sound
Try opening the door from the outside (or get someone else to do it for you) whilst sat in the car to see if it still does it. Then lift yourself off the seat and see if it stops. If it does stop whilst you are not sat down it may be a problem linked to the seat occupancy switch that activates when you sit down.
Posted on Oct 08, 2015
claudeinmo
  • 9098 Answers
SOURCE: Car will not start, a clicking whining noise. Lights flash, door lock no longer works
2001 Oldsmobile Alero Turns Over But Won't Start: 119 ...
www.carcomplaints.com/Oldsmobile/.../2001/.../turns_over_but_wont_st...
The 2001 Oldsmobile Alero has 119 complaints for turns over but won't start. ...Achieva · Aurora · Bravada · Calais · Cutlass · Cutlass Calais · Cutlass Ciera · Cutlass... We try giving it a jump, still does not start. .... oil sludge whining noise stalls while driving engine complaint electrical issue .... Mom my car wont start AGAIN.
Oldsmobile Forum Repair Questions- Newest Answers
www.greatautohelp.com/oldsmobile.php
Long story short the car will now start and idle when you step on the gas it will rev ....This whining noise seems to start when the engine temp goes above 200 degrees. ...hood from the outside on an 1999 oldsmobile aurora when i cant get in my car. .... My2001 Oldsmobile Aurora has had the battery disconnected due to a ...
Posted on Feb 08, 2016
Where is the thermostat location on 1998 Oldsmobile silhouette
Trace the top hose from the radiator to the engine. It is located in the piece that the hose connects to at the engine
Apr 04, 2015 | 1998 Oldsmobile Silhouette
Firing order and spark plug wiring digram
1998 Oldsmobile Silhouette 3.4 liter V-6 VIN "E"
Hope helps (remember rated and coment this).
Sep 06, 2010 | 1998 Oldsmobile Silhouette
Replacing mirror on 1998 Oldsmobile Silhouette
you'll need to remove your door panel (screws are by the door handle, arm rest, under door and side of door) and remove the cover adjacent to your mirror to remove the bolts to remove the mirror.
Aug 12, 2009 | 1998 Oldsmobile Silhouette
1998 oldsmobile Silhouette hard Steering
check the power steering fluid level, looks for any cracks or leaks in the pump, check the pully and belt as well.
Jun 11, 2009 | 1998 Oldsmobile Silhouette
ECM location 1998 Oldsmobile Silhouette
On the 98 Silhouette, the PCM should be located in the air filter housing.
May 20, 2008 | 1998 Oldsmobile Silhouette
Furniture Logo
510 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
