Question about Cameras
I was wondering how long it takes to format an SD card using the Canon GL2. I've tried numerous times with a standard one hour battery and the camera dies before the card is formatted.
  • Cameras Master
  • 32,281 Answers
Depending upon the size of the memory card a 16Gb memory card should only take a few mins.
Posted on Apr 20, 2013
  • 130 Answers
SOURCE: CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Posted on Mar 30, 2006
SOURCE: polaroid a300 camera is saying sd protected
Well, make sure you have checked the small gray tab on the left side of the sd card. It needs to be in the unlocked position. Too bad for me, because i have the same problem and my sd card isn't locked...
Posted on Dec 19, 2007
old marine
  • 2097 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
SOURCE: Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Posted on Apr 23, 2009
leepania
  • 1099 Answers
SOURCE: Can't format 8 GB SD memory card
The camera doesn't support this memory card.
Memory card support : SD/MMC up to 2 Gigabyte only.
Sorry you will have to downsize.... :)
If helpful pls. rate me and/or recommend me TXS
Posted on Dec 03, 2009
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 | Cameras
Konica minolta DiMage Z10 doesn't recognize sd card
Might one enquire how you have assessed the intelligence of the connecting lead ? I know of no definitive tests for this area of electronic equipment.
Mar 16, 2017 | Konica Minolta DiMAGE Z10 Digital Camera
Hello, i am having a problem with my Canon SD1200 IS camera, it was taking pictures fine, i accidentally left my memory card out in my computer and tried to take a photo with it out, but when i put the...
Hi Lara
I would take the battery out to reset it and put the chip in and then the battery and fire it up.
You can also clear the sd card in windows to avoid naming issues
After the card is accepted format it with the camera so the directory structure on the sd is restored
pls add thumbs if happy or leave me a comment if still in sorrow
cheers
rene
Jun 08, 2011 | Cameras
My A540 camera gives me a Memory card error when I put in a new card. I have tried different brands and checked the card lock switch. These cards work in another camera
Take a close look at the cards that you've used. Are they all 4GB or higher "SDHC" cards? If so, that's your problem. Your camera was made well before the SDHC format came out. Although the card looks exactly the same as a standard SD card, the format it uses is very different. Unfortunately, there is no way that your camera will work with SDHC format. It can only use standard SD (cards that are 2GB or less). Fortunately, these are very inexpensive these days (check Amazon).
Dec 07, 2010 | Canon PowerShot A540 Digital Camera
Can you use an SDHC card in the canon powershot sd300 digital elph?
Although it looks exactly the same as a standard SD card, the format the SDHC card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
A530 has message "memory card full". tried 2 cards same results.
1. First, try to format both the memory cards using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Dec 21, 2009 | Canon PowerShot A530 Digital Camera
I have a canon powershot SD400 elph. Camera menu
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Dec 12, 2009 | Canon Cameras
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
