Question about Toshiba PDR-3330 Digital Camera
Lost memory card
Have a toshiba pdr-3300 digital still camera, lost memory card cannot us anyother card unless have original to update,
  • 2 more comments
  • info202 Mar 11, 2009
    tried that says need original memory card to update then can use the new memory card
  • info202 Mar 12, 2009
    tried still says this card cannot be used, purchased two 1gb Sandisk"s
    well try thanks
  • info202 Mar 13, 2009
    That did it thank you
  • 423 Answers
Why can't you use a different card? Just put it in and format the new card in the camera.
Rob
Posted on Mar 11, 2009
  • 1 more comment
  • Rob
    Rob Mar 12, 2009
    Ok, I've read the manual for your camera and to fix your problem, you need to do this:
    Make sure the camera is off, then remove the batteries.
    Remove any card you have in.
    Leave it for 5 minutes.
    Then, replace the batteries and replace the card.
    Turn the camera back on.
    Then immediately format the new card via the camera menu.
    This should work. Let me know.
    Rob
  • Rob
    Rob Mar 12, 2009
    Ok, I figured out your problem. Your using 1gb cards. Your camera can only take up to a maximum of 128mb cards. Try a smaller card and I bet that will work.
    Rob
  • Rob
    Rob Mar 13, 2009
    If it works, which I'm sure it will, please consider re-rating my solution to a fixya. Thanks,
    Rob
I have 2GB SD card, when i insert it into camera, it will check and the show on screen that: This card cannot be used: How do i make it to work. What will i do. From Nwabueze Ogbonnaya
When you are sure here is nothing important on the SD card, you first should try to format it. If not possible in the camera, try it in a computer FAT 12 or FAT 16 should work.
But when you put in the card, make sure the card is not locked and the battery / memory card cover is closed and locked correct.
Everything is still in the manual.
Just to make sure you understand how to unlock the memory card I place a picture. The switch should be like on the 64GB card (up)
Jan 29, 2014 | Toshiba PDR-3300 Digital Camera
When i put my sd card in my camera wont turn on
The PDR-3300 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the camera. You need to use SD cards, 2GB and smaller.
May 13, 2012 | Toshiba PDR-3300 Digital Camera
I need a SD card and would like to know if there are any compatable SD cards fot the Toshiba PDR-3300. Thank you.
Any SD card will work. You don't need to specify a particular brand, and speed won't make any difference to the camera (though a faster card may speed up downloads via a card reader). Just make sure you get an SD card, not an SDHC card.
Oct 15, 2010 | Toshiba PDR-3300 Digital Camera
2gb sd card wont format this is a toshiba pdr-3300
Hi, is it an SD card of normal size? if so there's a little switch on the side which says protect, move this the other way to enable Formatting..
Thanks Mark
May 03, 2010 | Toshiba PDR-3300 Digital Camera
Missing memory card
In all probability the memory card that came with your PDR-3300 was:
SD 8 MB Toshiba Memory Card.
SD cards with a much larger MB can be obtained at any large Drug Store, i.e. Walgreens, CVS, etc.
At the present time, these cards, 32 MB and larger are very inexpensive.
Feb 18, 2009 | Toshiba PDR-3300 Digital Camera
Memory card locked
pull the SD card from the the slot and it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jan 11, 2009 | Toshiba PDR-3300 Digital Camera
What kind of SC memory card do I need to get for a Toshiba PDR-3330 digital still camera?
The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
8MB, 16MB, 32MB, 64MB, 128MB, and 256MB"
Aug 22, 2008 | Toshiba PDR-3330 Digital Camera
PNY 2GB memory card
I have the same camera and bought a 4GB PNY SD card and it wouldn't work, so I read the manual :) The manual says, "SD Memory Cards having the following storage capacity can be used on your camera (Toshiba PDR-3330):
Hope this helps! -Kim
Jul 15, 2008 | Toshiba PDR-3330 Digital Camera
Problem with camera writing to memory card
try this first: pull the SD card from the the slot and hold it right side up with the label facing you, there is a short slot on the side with a sliding switch. move it to the other side of the slot and that will unlock the card. (it probably go moved as your were putting the card back into your camera) good luck!
Jun 23, 2008 | Toshiba PDR-3300 Digital Camera
Erase Images
Press the trashcan button to erase a single image. Press and HOLD the trashcan button for the option to erase many images, all images, or to format the SD Card. It is good to Format the SD Cad from time to time after downloading the images to clear all residual memory files (even if you do not see them).
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Toshiba PDR-3330 Digital Camera Logo
192 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
