I wnt to connect external hardrive to my BenQ Vk3211 Tv. Input hdmi port. To see al files and wach my movies
honeybaked74
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: No signal input when connecting PC to LG TV via HDMI
Do you also have a computer monitor attached to the computer when attempting to use the HDMI?
Posted on Mar 30, 2009
  • 120 Answers
SOURCE: what is easylink connection? Wireless? HDMI?
The Easylink is Philips name for HDMI CEC which allows multiple HDMI devices to control each other with one remote.
As for the sound...it looks like there is only one audio out and it's in the form of coaxial cable which isn't very helpful.
What I would suggest is that you tap the audio coming from the input. So I'm assuming your TV is connected to a cable/dish box. Use the audio out from that to power your headphones or external speakers. This will likely mean you can't use the HDMI or will need a splitter, but at least it will solve your issue.
Posted on Oct 16, 2009
tgr2000667
  • 30 Answers
SOURCE: I cannot get the Input
input is shared with component input--one or the other --must choose in set up menu
Posted on Jul 13, 2010
  • 1583 Answers
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Posted on Oct 13, 2010
Testimonial: "Thank you for giving me another avenue to explore."
I have a mitsubishi HD1080 series TV and wanted to know how do I plug in a dvd player. Then how do I get it to play.
Connect an HDMI cable from the DVD's HDMI port to an unused HDMI port on the TV. Select the input from the settings menu and name it DVD or select the DVD name. Turn the DVD player ON. Using the input select button on the remote, select the HDMI DVD input. Wait a few seconds while the TV and DVD player establish a connection. The DVD player menu should appear. Insert a DVD and enjoy a movie. Hope this helps. Regards.
Jan 02, 2016 | Mitsubishi Televison & Video
How do I get external screen on laptop to use on a TV screen?
It really depends on the type of equipment you have. Does your laptop have a HTML port? And does your TV have a HTML port? You can google your Dell laptop on how to make the config settings for displaying on an external monitor (TV) for your particular laptop model. I have done it with the VGA port to an external monitor very easily. The HTML will need some special settings depended on how old your laptop is. Good luck.
May 04, 2015 | Dell LATITUDE Computers & Internet
How do I use a USB to watch a movie on Toshiba TV? Or hook computer up to TV to watch it?
Hi
Most recent laptops come with a port to connect to a TV, depending upon the input ports the TV has. The two most common are VGA and HDMI, and you will need to check which of these each item has. It is then simply a case of getting the appropriate cable to connect the two together, and then on the TV select the input from the menu, and on the laptop, make sure that the external video port is active (usually a Fnct and "F" key - eg Fnct + F5 for a Toshiba Satellite Pro U200).
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 08, 2015 | Toshiba Televison & Video
How do i play movies from a tablet i plugged a hdmi cord but no response
You mentioned a "usb cable" but you cannot connect an external display to a tablet's USB ports. If you are using an HDMI cable, then you will need to select which display is active through the tablet's settings (Android) or control panel (Windows) and also make sure that the TV is set to the appropriate HDMI connection through the input selection.
Dec 31, 2014 | Toshiba 19SL410U 19 LCD TV
How do get my k100 to work on my tv
1. Connect your laptop with your TV using a cable (HDMI or VGA),
2. Turn on your TV and change the input in your TV (PC input/VGA/HDMI. Please notice that some TV have more than one HDMI input port, so you need to check it which port is connected to your computer),
3. Turn on your laptop and change the output in your laptop (cycle it: laptop only, external display only, both) using Fn key and the screen cycle F key (please see the orange icon on the F keys).
Mar 01, 2014 | Advent Computers & Internet
Acer lap top to Samsung plasma
Depends on what type of ports your HP has and what type of ports your Samsung TV has. The easiest connection is to try to connect using the ports that they both have. Otherwise, if they have different ports then you will need some type of converter that goes between the two of them to make them communicate.
Most computers have a VGA port, does the Samsung TV have a VGA Port? New computers have a HDMI port, does the Samsung TV have a HDMI Port? If so you the connections that are alike or you will need a converter.
Once you have them connected, you just have to select the Input on the TV. Most times if you use VGA then you select PC or Computer as the input. There should be an HDMI input selection if you use HDMI connections.
Reboot the computer and the display might appear on the tv. If not you will have to hit some keystrokes to toggle the display between the computer and the tv. Most times on the computer you will hit the FN function key and one of the F1 thru F12 keys that controls the display on an external. The correct F1 thru F12 key will have LCD/CRT on it or it will have the icon of a display. Press and Hold the FN function key then hit the correct Function key (F1 thru F12) that toggles the display.
Apr 07, 2012 | Computers & Internet
Hello I have some movies on my laptop but now I want to wach them on tv on my TV I have only scart-input,experts told me I need a cable with D15 connecting from my laptop to one transformer to my...
Most Laptops use S-Video as a way to display video on your TV screen.
You can pick up a S-Video cable at your local Electronics store IE Radio Shack. Before purchasing the cable ensure your TV has the correct input.
The four main types are (in increasing quality):
1. S-Video [2 types: 4Pin as in picture'7Pin]
Port: http://www.coloredhome.com/video/s-video...
Cord: http://akamaipix.crutchfield.com/graphic...
2. VGA
Port: http://upload.wikimedia.org/wikipedia/co...
Cord: http://www.thisishowyoudoit.com/blogimag...
3. DVI
Port: http://vocaro.com/trevor/blog/wp-content...
Cord: http://www.tech-faq.com/dvi-hdtv-connect...
4. HDMI - also transfer sound signal
Port: http://media.bestofmicro.com/,2-3-49323-...
Cord: http://www.k1cable.com/images/hdmi_000.j...
All of these do the same thing: The laptop sends the video information through the Port and the Cord. Your TV Recieves that information in its port. Numbers 1 to 3 do not transfer sound, so you will need a separate adapter for your headphone to TV Audio. #4 HDMI transfers both sound and audio data, so you won't need a separate cable for sound.
Check if your TV has corresponding ports. If not, you can buy adapters. This is an example of a VGA to RCA(Red/White/Yellow analog cables) and S-Video
http://img.alibaba.com/photo/52306528/VG...
Thanks for rating good luck
Jan 13, 2011 | Computers & Internet
Is there an HDMI input on this tv? And if so, where?
No,there are no HDMI ports in this tv design.This lower end of LCD tv made especially for Target it only get to resolution max 720p,so no HDMI ports.Only can connected devices as RCA component cables Yellow Red White only as for AV input for external devices attactments.
Dec 28, 2010 | TruTech PM1919BXA1 19 in. LCD TV
I can't play movies on my tv
Okay, this monitor setup is a little strange. There is an "AVC" component with this monitor that you use to connect everything. There is a 4 cable string (power, s-video, DVI, display port) that connects the AVC unit to the monitor. You must have all external equipment connected to the AVC unit, not to the TV itself. The connections on the TV talk to the AVC unit. I will assume you will be connecting the Blu-ray player via HDMI. HDMI is on input 4 on the back of the AVC unit. hit the input button on the remote or the TV and select input 4. There is a way of customizing the inputs to read out what you have connected to them (ex. DVD, VHS, etc.) to make it easier to use. This should get you signal from your blu-ray
Nov 06, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Mar 29, 2009 | Acer Aspire m5640 PC Desktop
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
