Games freezing up
I have sound. The video freezes up. Video is not compatible with my windows XP
  • 1,602 Answers
OUT DATED SOFTWARE, CORUPTED SOFTWARE OR DRIVERS, RESOLUTIONS IN INCORRECT, THE REFRESH RATE IS INCORRECT, VIDEO CARD HAS A IRQ OR AND DMA ERRORS, THE SOFTWARE HAS TO BE ACTIVATED, THE GAME NEEDS TO BE RE-ACTIVATED, AFTER EVERYTHING YOU MAKE CHANGES TO THE SYSTEM CONFIGURATION, LIKE VIDEO, RAM, MB, MAYBE NEW SOFTWARE AND NEW HARDWARE SO IF YOU BEGIN TO HAVE ISSUES WITH A PRODUCT YOU WILL HAVE A PLACE TO HELP YOU FIND A SOLUCTION TO YOUR CURRENT PROBLEMS.
INSTALL VIDEO CARD AND GO INTO CONTROL PANEL AND CHOOSE INSTALLING NEW HARDWARE.
********************USE THIS WHEN YOU START HAVING PROBLEMS INSTALL NEW SOFTWARE AND HARDWARE THAT ARE CAUSING INSTALATIONAL PROBLEMS*************
ONLY USE THESE INSTALL PROGRAM AND HARDWARE
ARE GIVING YOU PROBLEM INSTALL NEW DEVICES
ANY OTHER TIME DONT USE IT UNLESS YOU JUST WANT TO DO IT FOR THE FUN OF IT.
ROD
Posted on Mar 13, 2009
Pharaoh and cleopatra freezes constantly
Probably a bit late, but here are the best fixes I found:
First off, you want to:
*** Change compatibility to Windows XP (SP3)
*** Disable Visual Themes
*** Run as admin
Next you want to:
Download the pharaoh exe files (these are for modifying the resolution - this is what worked for me - I used the lowest res available, so I cannot comment on higher ones)
http://www.wsgf.org/dr/cleopatra-queen-nile/en
Or you can try this fix:
https://web.archive.org/web/20080721084339/http://www16.brinkster.com/salvage/thief/imagecfg.zip
"Download ImageCFG
Extract the .zip and place imagecfg.exe in your game's folder.
Create a batch file. First, open up notepad and paste the following.
@echo off
if not exist Pharaoh.exe goto end
if exist Pharaoh.exe.bak goto end
copy Pharaoh.exe Pharaoh.exe.bak
imagecfg -u Pharaoh.exe
imagecfg -a 0x1 Pharaoh.exe
pause
:end
Save as a .bat file and place it in your Pharaoh installation folder.
Run the batch file.
This will change the CPU affinity of Pharaoh so it will run on one CPU core."
This fix taken from here:
http://pcgamingwiki.com/wiki/Pharaoh
Mar 27, 2012 | Sierra Entertainment Pharaoh And Cleopatra...
My game Desperate housewives freezes on episone 6 on 7pm, what can I do?
I FINALLY FOUND OUT THE ANSWER... Okay, right click on the game and change the compatibility mode to windows xp (service pack 3) then right click the game and hit "run as administrator" then when playing the game, when it gets to be about 6:45-6:50 seduce someone (ANYONE!) Then after the... seduction, it will be abnout 7:20... It will then automatically put you into the poker game!
Mar 23, 2012 | Video Game Consoles & Games
Game is slow and freezes
try to check your video settings . try to lower ur video settings to medium and try to the game. if problem persist try reinstalling the game. also check your video card compatibility with the game.
Jul 03, 2011 | Dreamcatcher War Leaders: Clash of Nations...
I had installed the game called WILL ROCK and while starting the game gsvideo Init failed is showing and the game is not playing.
Make sure you all have this system requirements.
MINIMUM PC REQUIREMENTS
Windows 98/ME/2000/XP
MINIMUM
Pentium III 500MHz or AMD Athlon 550MHz Processor
128MB RAM
32MB DirectX compatible 3D Accelerated Video Card
DirectX compatible Sound Card
DirectX 9.0
4X CD-ROM Drive
700MB Hard Disk Space
RECOMMENDED
Pentium III or AMD Athlon 800MHz Processor
256MB RAM (Windows XP)
64MB DirectX compatible GeForce3 or ATI Radeon Video Card
Mar 19, 2011 | Computers & Internet
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
When i start Axis and Allies the screen flashes for about 15 seconds and then an error screen comes up that says that "the game tried to turn the resolution to 1024/768 but couldn't so it changed it back...
When I try to play Axis and Allies cd-rom '98 it's like the screen is too small for the game because there is no buttons or anything that allows me to end my turn. My monitor is pretty big too.
Jul 07, 2009 | Video Game Consoles & Games
Games, video keep freezing
your vc might be heating up, try to remove it agai. take the heatsink out and then put a thermal paste on it before returning it on the vc, then install it again and see if that will works.
Apr 07, 2009 | Computers & Internet
I don't what the problem is.
Firstly have you considered it is the game? try restalling
If that doesnt work, it is most likely your video card. dxdiag into run and click all the run test buttons you can see.
Update video drivers and try installing to a different pci slot.
It may be the video cards ram instead of your pcs ram.
but check the pcs ram is compatible.
Oct 08, 2008 | XFX GeForce FX 5500 Graphic Card
Image freezes
My computer freezes every time I use my camera. What can I do?
trnsp.gif Answer Normally if a camera freezes after a few seconds, it is related to the USB chipset you are running. Some chipsets do not have enough bandwidth to support a camera. Make sure you are plugging the camera directly into the computer while testing and unplug any other USB devices you may have except a keyboard or a mouse.
To resolve the issue, we recommend using the USB troubleshooting steps detailed in Troubleshooting USB Issues.
If you have the same issue but do not have the USB chipsets discussed in the document, please make sure you have the latest version of the Logitech camera software AND the latest version of DirectX.
You may also want to slow down the hardware acceleration. To do this, right click on the desktop and choose Properties. Click on Advanced/troubleshoot. Lower the hardware acceleration, apply any changes and try the camera again.
If you are running Windows XP, please make sure you have the latest sound card, video card and Windows XP updates. You can get the sound card and video card updates from the card manufacturers or PC manufacturers web site. You can get the Windows XP updates from Microsoft. With the release of any new operating system, we suggest that you check for updates to the operating system and hardware drivers. These updates can resolve many video streaming issues.
Mar 22, 2008 | Logitech Webcam
Game Freezes up CPU
your video card cannot support the graphics that game is trying to run. Try setting the graphics on the game's menu to a lower resolution or get a higher powered video card.
Mar 11, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
