Question about Garden
What ratio of gas to oil in my remington weed eater
panilling9
  • 284 Answers
SOURCE: weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
Remove fuel cap slowly
when refueling.
HELPFUL TIP
To obtain the correct oilmix
ratio, pour 3.2 ounces of
2--cycle synthetic oil into
one gallon of fresh gas.
This engine is certified to operate on unleaded
gasoline. Before operation, gasoline must be
mixed with a good quality synthetic 2-cycle
air-cooled engine oil designed to be mixed at a
ratio of 40:1. Poulan/Weed Eater brand
synthetic oil is recommended.Mix gasoline and
oil at a ratio of 40:1. A 40:1 ratio is obtained by
mixing 3.2 ounces (95ml) of oil with 1 gallon (4
liters) of unleaded gasoline. DO NOT USE
automotive oil or marine oil.
Posted on Jul 05, 2009
stmc97
  • 41 Answers
SOURCE: what is the oil to gas ratio for the husqvarna
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
Posted on Apr 11, 2010
  • 468 Answers
SOURCE: GAS TO OIL RATIO
Homelite products are 40:1 gas to oil ratio
Posted on May 28, 2010
Testimonial: "QUICK & PRECISE!! A GREAT HELP, & GOOD WAY TO FIND ANSWERS."
SOURCE: What is proper gas/oil fuel ratio for TORO Model
50:1
Posted on Jul 02, 2010
  • 5166 Answers
SOURCE: What is the gas to oil ratio for weed eaters?
Most gas weed eaters use 2-cycle engines. For the Homelite 2-cycle engine trimmers, use a 50:1 ratio of gasoline to the Homelite lubricant. (For 1 gallon of gas, add 2.6 oz of the oil.)
Many Homelite tool manuals are available here: http://www.homelite.com/service_support/product_owners_manuals . Scroll down to find your string trimmer.
I hope this helps.
Posted on Jul 17, 2011
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
What is mixing ratio for weedater
The ratio is generally 40 to 1. That is all I have ever used. It depends also though on the quality of the oil you use. Synthetics can use a different ratio than mineral oils.
Sep 19, 2014 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the oil ratio for the poulon pro link weed eater
Hi brochon
Use a 50 to 1 ratio...1 pint 2 cycle oil to 6 gallons of gasoline
Please take time to rate me
Aug 28, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I hope this helps.
Jul 16, 2011 | Homelite Garden
My weedeater brand trimmer won't start
I believe you have the wrong GAS AND OIL MIXTURE. MOST WEED EATERS are a Ration of 90:1 or even less 75:1 For WEEDEATER I would use a 50:1 or if you choose 32:1 should work. Use a good 2-stroke oil. DO NOT USE ANY OTHER OIL> You see the more oil you use the harder it is to start. Don't forget to Pump the fuel Bulb on the side before trying to start it.About 3 x should do it. GOOD LUCK and it is and does effect me when their is death by a LOVED ONE. My prayers are with you! From Mddoc13 ( BOB)
Aug 28, 2009 | Craftsman 25cc Gas Line Trimmer
Weed eater TE475 - fuel ratio
FUELING ENGINE
WARNING:
when refueling.
HELPFUL TIP
Jul 05, 2009 | Yard Machines Garden
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
May 23, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
1,652 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
