Question about Bunn My Cafe MCP
My Bunn my cafe will not prime what do you do.
It is a brand new machine and it will not do its initial prime
My bunn cafe red light flashes does not take water to tank nnot heating either. why?
my bunn has 2 switches one on the left side to keep it HOT and the front one when brewed to keep it hot . the side switch if off will not heat the water and will not let the front heater be turned on either which is lighted
Dec 14, 2015 | Bunn My Cafe MCU Universal 4-in-1 Single...
Machine produces a bad burning smell when making coffee and the coffee also tastes very burnt. The machine is 5 years old
Sorry but if it were mine I think I would discard and buy a new one.Personally LOVE my bunn . not a fancy expresso maker but really good American coffee
Jun 17, 2015 | Sunbeam Cafe EM6910
Could a solenoid that was initially wired wrong cause a fuel pump to stop priming or, burn the pump up?
You could have fried the motor in the pump.
If you have battery voltage at the pump with the pump relay is engaged, and a good ground, and the pump does not run, chances are the pump is cooked.
Jun 15, 2015 | 1987 Ford Ranger
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
Service engine error 181.514
Service Engine Error 181.2049 Maint failed to prime back pressure
This error most frequently happens during the initial printer setup. Another reason for this error to occur is when using malfunctioning cartridges or cartridges that do not have enough ink to complete the initial setup of the printer.
Inserting a new set of setup cartridges or by using the setup cartridges provided with the machine would resolve this issue. To identify whether you are using the setup cartridges.
If you are already using the new setup cartridges, unplug the power adapter from the back of the printer and re-plug it after five seconds and let the machine attempt a second initial setup.
Jul 26, 2014 | Lexmark OfficeEdge Pro 5500 Inkjet...
Won't shut off after making a cup
It sounds like the thermostat or Element is failing and causing your unit to overheat and boil. Probably time to call Bunn and see if your unit is under warrenty.
May 03, 2014 | Bunn My Cafe MCP
How do i clean my cafe before first time use.
Add about a half cup of white vinegar to the water an run it through
the maker about three times.After that use fresh water about three times. should be cleaned out .
Apr 15, 2014 | Bunn My Cafe MCP
Need to calibrate bunn mcp. Help?
This model of brewer doesn't allow for changes in the calibration. If you've been using it for a while and notice a change in volume chances are the brewer needs to be cleaned. Here is a link to the full manual. http://www.bunn.com/pdfs/manuals/41980.0000.pdf
Feb 04, 2014 | Bunn My Cafe MCP
Bunn My Cafe MCP Logo
78 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
