Question about Comdial Dx-80 7260-00 Digital Executive Phone
Icm mode function - Comdial Dx-80 7260-00 Digital Executive Phone
Does a 2004 chevy venture van have a coil pack?
Your Van ? Yes it does !
• Ignition control module (ICM) and ignition coils
Three dual tower ignition coils are mounted to the ICM, and are serviced individually. The ICM performs the following functions:
- The ICM receives and processes the signals from the CKP sensor B.
- The ICM determines the correct direction of the crankshaft rotation, and cuts spark and fuel delivery to prevent damage from backfiring if reverse rotation is detected.
- The ICM determines the correct coil triggering sequence, based on the 7X CKP signal. This coil sequencing occurs at start-up, and is remembered by the ICM. After the engine is running, the ICM will continue to trigger the coils in the correct sequence.
- The ICM produces and inputs 3X reference signals to the PCM.
- The ICM contains the coil driver circuits that command the coils to operate.
• Crankshaft position (CKP) sensors
The CKP sensor B is a variable reluctance sensor. The magnetic field of the sensor is altered by a crankshaft mounted reluctor wheel that has seven machined slots, six of which are equally spaced 60 degrees apart. The seventh slot is spaced 10 degrees after one of the 60 degree slots. This sensor provides the ignition control module (ICM) with 7X signals, or seven pulses for each revolution of the crankshaft. The pulse from the 10 degree slot is known as the sync pulse. Both of the sensor circuits are connected to the ignition control module (ICM). A signal converter within the ICM produces digital 3X output pulse to the powertrain control module (PCM), the 3X reference is known as the low resolution engine speed signal.
The CKP sensor A contains a hall-effect switch. A hall-effect switch is a solid state switching device that produces a digital ON/OFF pulse when a rotating element passes between the sensor tip and a magnet. This rotating element is called an interrupter ring or blade. In this case the interrupter ring has 24 evenly spaced blades and windows and is part of the crankshaft damper assembly. This sensor provides the PCM with 24X signals, or 24 identical pulses per crankshaft revolution. The 24X signal is used for enhanced smoothness and idle stability at a lower calibrated RPM. The PCM supplies the sensor with a 12-volt reference, low reference, and signal circuit.
• Camshaft position (CMP) sensor
The CMP sensor signal is a digital ON/OFF pulse, output once per revolution of the camshaft. The CMP sensor does not directly affect the operation of the ignition system. The CMP sensor information is used by the PCM to determine the position of the valve train relative to the crankshaft position. By monitoring the CMP and CKP signals the PCM can accurately time the operation of the fuel injectors. The PCM supplies the sensor with a 12-volt reference, low reference, and signal circuit.
Jun 13, 2017 | Cars & Trucks
2004 chevy impala start car runs about10 minutes then stalls new fuel pump when stalls cut out like running out of gas then don't start till cools off if electical to me would cut out instantly help
Not if ignition module . Electronic componets when heated up will act just like that . When it dies check spark, fuel pressure right away an find out what quit . Test don't guess . Videos on youtube on testing GM ignition system. Which engine does yours have ? Had option of two different ones . 3.4 an 3.8L . Ignition module or cranhshaft position sensor could be the cause .
• The ICM supplies a power and low reference circuit to the CMP and CKP sensors.
• The ICM determines the correct direction of the crankshaft rotation, and cuts spark and fuel delivery to prevent damage from backfiring if reverse rotation is detected.
• The ICM determines the correct coil triggering sequence, based on how many 18 X ON-OFF pulses occur during a sync pulse. This coil sequencing occurs at start-up, and is remembered by the ICM. After the engine is running, the ICM will continue to trigger the coils without the CKP sync pulse.
• The ICM inputs 18 X and 3 X reference signals to the PCM.
• The 3 X reference signal is also known as the low resolution engine speed signal. This signal is generated by the ICM using an internal divide-by-six circuit. This circuit divides the 18 X signal pulses by 6. This divider circuit will not begin operation without a sync pulse present at start-up, and without 18 X and 3 X reference signals no fuel injection will occur.
Pull plug wires off same coil when it dies , crank the engine , is there spark ? Ignition Control Modules ICM by Wells featuring Sgt Tech
Nov 12, 2016 | 2004 Chevrolet Impala
I recently replaced the coils the icm cam sensor and crank sensor and still getting a p1350 code on my 94 lesabre . how can i fix this please?.?
DTC P1350 Bypass Line Monitor
Refer to Ignition Control, Knock Sensors .
Circuit Description
The Ignition Control Module (ICM) sends signals that the PCM requires for fuel control and spark advance calculations. At the start of engine crank, the ICM controls spark advance (Bypass mode.) When the second 3X reference pulse is recognized by the PCM, the PCM applies 5 volts to the Bypass circuit, commanding the ICM to switch spark advance to PCM control (IC mode). An open in the IC circuit or a short to voltage in the Bypass circuit at startup will cause the PCM to monitor IC pulses during crank, when the ICM should be grounding the IC circuit. This condition will set DTC P1350. The engine may be started but will run on Bypass mode timing.
Conditions for Setting the DTC
The PCM monitors IC pulses during crank while Bypass mode spark advance is commanded
Action Taken When the DTC Sets
The PCM will illuminate the malfunction indicator lamp (MIL) during the second consecutive trip in which the diagnostic test has been run and failed.
The PCM will store conditions which were present when the DTC set as Freeze Frame and Failure Records data.
Conditions for Clearing the MIL/DTC
The PCM will turn OFF the MIL during the third consecutive trip in which the diagnostic has been run and passed.
The History DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using the scan tool.
Diagnostic Aids
Check for the following conditions:
Poor connection at the PCM. Inspect harness connectors for backed out terminals, improper mating, broken locks, improperly formed or damaged terminals, and poor terminal to wire connection.
Damaged harness. Inspect the wiring harness for damage. If the harness appears to be OK, disconnect the ICM, turn the ignition ON and observe a digital multimeter connected between the IC circuit and B+ while moving connectors and wiring harnesses related to the ICM. A change in voltage will indicate the location of the malfunction.
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Test Description
Number(s) below refer to the step number(s) on the Diagnostic Table.
This vehicle is equipped with a PCM which utilizes an Electrically Erasable Programmable Read Only Memory (EEPROM). When the PCM is being replaced, the new PCM must be programmed.
Oct 14, 2016 | Cars & Trucks
94 camaro wont start...no firefrom the coil has new icm , coil , fuel pump
Check the icm plug with a led testlight for pulse while the engine is cranking. Test the wire connector with the small wires going into the coil for pulse.The v8 has a opti-spark distributor behind the waterpump that is prone to failure. It has the pickup inside it that tells the icm when to spark. If no pulse at icm distributor is bad. If pulse at icm but not at coil, icm or wiring between icm and coil is bad.The coil also needs pos.+ power on 1 terminal to operate. Be SURE to check the security light on the dash. If VATS [vehicle anti theft system] fails its usually within the 2 wires going from the key chip in the ignition tumbler to the body control module. Mine were purple and tan.Trying to start it with the wrong key can put it in lockout mode also. There are bypass modules available online for vats problems or you can even install a resistor in the wire to bypass the keychip part and the door alarms still work.
Mar 27, 2014 | 1994 Chevrolet Camaro
Ignition control module problems
If any of the ignition components fail, you should get a check engine light and a trouble code for that component.
Are you getting any codes ?
May 17, 2013 | 2001 Buick LeSabre
Idle fluxuates up and down consistantly
Check the Idle Control System
Idle speed is controlled by the Idle Air Control Valve (IACV). The IACV changes the amount of air being bypassed to the intake manifold, in response to electric current controlled by the ECM. When the IACV is activated, the valve opens to maintain proper idle speed.
Symptom and Subsystems to Check:
1. Difficult to start engine, when cold--check Fast Idle Thermo Valve.
2. Fast idle out of spec, when cold:
a. Check Fast Idle Thermo Valve.
b. Check IACV.
c. Check idle adjusting screw (see Section C).
3. Rough idle:
a. Check hoses and connections.
b. Check IACV.
4. RPM too high, when warm:
a. Check IACV.
b. Check Fast Idle Thermo Valve.
c. Check hoses and connections, check Power Steering Pressure Switch Signal, and check idle adjusting screw.
5. RPM too low, when warm:
a. Idle speed is below specified rpm, with no load--check IACV and idle adjusting screw.
b. Idle speed doesn't increase after initial start up--check IACV.
c. Idle speed drops in gear (automatic transmission)--check automatic transaxle gear position switch signal.
d. Idle speed drops when AC is on--check air conditioning signal and IACV.
e. Idle speed drops when steering wheel is turned--check power steering pressure switch signal and IACV.
f. Idle speed fluctuates with electrical load--check hoses and connections, IACV, and Alternator FR Signal.
6. Frequent stalling, while warming up--check IACV and idle adjusting screw.
7. Frequent stalling, after warming up--check idle adjusting screw and IACV.
Additional Steps:
. Check Alternator FR Signal. Have alternator inspected, if idle speed fluctuates with electrical load. The FR signal communicates to the ECM how "hard" the alternator is working to meet the electrical demands of the car, including the battery and any loads which aren't monitored by the ELD. This square-wave signal varies in pulse width, according to the load on the alternator. The ECM places, approximately, 5 reference volts on the wire. The voltage regulator will drop this signal to approximately 1.2 volts, in proportion to alternator load. The ECM compares the electrical load (ELD) signal with the FR (Charging Rate) signal from the alternator and uses that information to set the idle speed and turn the alternator on and off. This helps fuel economy.
. Clean main ECM ground on thermostat housing.
. Reset ECM, by removing the 7.5 amp Back Up Fuse, in the under-hood fuse box, for 10 seconds.
. Replace PCV Valve, cleaning hose with brake cleaner spray.
. Substitute a known-good ECM. If symptom goes away, replace original ECM.
Check the ICM (Erratic RPM and PGM-FI System)
When the engine is cold, the air conditioner compressor is on, the transmission is in gear (automatic transmission only) or the alternator is charging, the ECM controls current to the Idle Air Control (IAC) Valve to maintain correct idle speed. Here's an overview of how the PGM-FI System works.
Background:
Various inputs to the ECM are TDC/CKP/CYP Sensor, MAP Sensor, ECT Sensor, IAT Sensor, TP Sensor, HO2S, VSS, BARO Sensor, EGR Valve Lift Sensor, Starter Signal, Alternator FR Signal, Air Conditioning Signal, Automatic Transmission Shift Position Signal, Battery Voltage (Ignition 1) Brake Switch Signal, PSP Switch Signal, ELD, and VTEC Pressure Switch.
Inputs are received and processed by the ECM's Fuel Injector Timing and Duration, Electronic Idle Control, Other Control Functions, Ignition Timing Control, and ECM Back-up Functions. These are the primary functional areas within the ECM.
Outputs from the ECM control Fuel Injectors, PGM-FI Main Relay (Fuel Pump), MIL (Check Engine Light), Idle Air Control (IAC) Valve, A/C Compressor Clutch Relay, Ignition Control Module (ICM), EVAP Purge Control Solenoid Valve, HO2S Heater, EGR Control Solenoid Valve, Alternator, Lock-up Solenoid Valve A/B (A/T), VTEC Solenoid Valve, and Interlock Control Unit.
Idle RPM:
Once you understand how the PGM-FI system is configured, it's easy to see how the ECM, Idle Air Control Valve, and the Ignition Control Module affect idle rpm. If the ECM's Electronic Idle Control function is not working properly, then it cannot properly control the IAC Valve. Likewise, if the ECM's Ignition Timing Control function is not operating properly, it cannot properly control the ICM (igniter). Obviously, idle rpm will also be affected if there's a problem with the IAC Valve or the ICM. As stated above, the ECM controls current to the Idle Air Control (IAC) Valve to maintain correct idle speed. This cannot happen if the IAC Valve is failing. The same situation exists if the ICM is failing. The ECM will tell the ICM to open and close the primary voltage circuit going to the coil and it won't respond properly. The result will be erratic spark plug firing and erratic rpm.
Conclusion:
If you are experiencing erratic idle rpm, try and isolate whether the problem is caused by the ICM (ignitor), IAC Valve, or the ECM. My experience has been that a failing ICM is usually responsible for the problem. Keep in mind that tachometers are connected directly to the ICM. Therefore, a fluctuating tachometer needle is often a dead giveaway. Heat and poor preventive maintenance (causing high secondary voltage to be discharge on internal distributor components) frequently causes the ICM (and coil) to fail. Besides performance, this is another reason why it's important to regularly replace spark plugs, spark plug wires, rotors, and distributor caps. Electricity will always follow the path of least resistance, even if it isn't the intended one. Our job is to ensure the intended path is the path of least resistance.
Ignitor (ICM) and Coil Replacement:
1. Disconnect negative battery cable.
2. Remove hex head machine screws, securing distributor cap to housing, using an 8 mm nut driver.
3. Move distributor cap and wires off to the side.
4. Remove machine screw securing rotor to shaft, using a #2 Phillips head screwdriver. It may be necessary to "hit" the starter once or twice, in order to rotate rotor for access to mounting screw.
5. Remove rotor and leak cover.
6. Unfasten ignitor wires, remove coil mounting screws, and set coil aside. Note: Removing coil first improves access to igniter.
7. Unfasten screws securing igniter to housing.
8. Remove ignitor from distributor and unfasten screws mounting ignitor to heat sink.
9. Coat back of new ignitor (or old igniter, if reusing) and male connectors with silicone grease. Silicone grease increases heat transfer to heat sink. Failure to apply silicone grease will cause the ignitor to quickly fail.
10. Mount ignitor to heat sink and reinstall ignitor, igniter terminal wires, coil, coil wires, leak cover, rotor, and distributor cap. Ensure female ignitor terminals fit snugly--crimp with pliers, if necessary.
AutoZone can test ICMs and coils for free. If you plan to keep the car, I would replace the ICM due the age of your Civic.
Sep 15, 2010 | 1991 Honda Civic
1996 FORD EXPLORER , MISS FIRE ON CYL # 2, 1ST REPLACED PLUGS AND WIRES, THEN THE COIL PACK AND LAST THE FUEL INJECTOR BUT PROBLEM STILL THERE, ANY HELP WOULD BE GREAT
OK,
Have you tried the following:
Ignition Control Module (ICM) REMOVAL & INSTALLATION NOTE: Only the EEC-IV ignition systems use an external ICM. EEC-V systems have incorperated the ICM into the Power Control Module (PCM).
  1. Disconnect the negative battery cable.
  2. Detach the wiring harness connector(s) from the ICM.
  3. Remove the mounting bolts, then remove the ICM. To install:
  4. Position the ICM onto the inner fender apron and install the mounting bolts. Tighten the bolts to 22–31 inch lbs (2.5–3.5 Nm).
  5. Attach the wiring harness connector(s) to the ICM.
  6. Connect the negative battery cable. Fig. 1: Ignition control module and mounting location on the 2.3L, 2.5L engine 89682g32.gif
    Fig. 2: Ignition control module used on all EEC-IV systems except the 2.3L engine 89682g33.gif
    Fig. 3: Ignition control module mounting on all EEC-IV systems except the 2.3L engine 89682g34.gif
Jul 11, 2010 | 1996 Ford Explorer
How do you remove the ignition coil
Each ignition control module (ICM) has the following circuits:
An ignition 1 voltage circuit A chassis ground An ignition control circuit for each cylinder A low reference circuit
The PCM controls spark by pulsing the ignition control circuits to the ICM to trigger the coils and fire the spark plugs. The PCM and ICM are internally protected against shorts to power and ground on the ignition control circuits.
The spark plugs are connected to each coil by a short boot. The boot contains a spring that conducts the spark energy from the coil to the spark plug. The spark plugs are tipped with platinum for long wear and higher efficiency.
Ignition Control Module (ICM) Connectors
Fig. Ignition coil locations 2001-2004 4.8L, 5.3L, 6.0L Engines
Removal & Installation
2.2L (L61) Engine
  1. Turn OFF the ignition.
  2. Remove the accelerator cable from the bracket.
  3. Remove the accelerator cable bracket bolt.
  4. Remove the accelerator cable bracket.
  5. Disconnect the ignition control module (ICM) harness connector.
  6. Remove the ICM retaining screws.
  7. Remove the ICM from the ignition coil housing.
To install:
  1. Install the ignition control module in the ignition coil housing.
  2. Install the ICM retaining screws. Tighten the retaining screws.
  3. Connect the ICM harness connector.
  4. Install the accelerator cable bracket.
  5. Install the accelerator cable bracket bolt. Tighten the retaining screws.
  6. Install the accelerator cable to the bracket.
2.2L (Ln2) Engine
  1. Remove the air cleaner outlet from the air cleaner.
  2. Remove the ICM electrical connectors (1) and spark plug wires (2).
  3. Remove the ignition coils bolts (3).
  4. Remove the ignition coils and ICM assembly.
  5. Installation is the reverse of the removal procedure.
2.4L Engine
  2. Remove the accelerator cable from the hold down clip.
  3. Remove the cruise control cable, if applicable.
  4. Remove the bolt from the fuel line retaining clip.
  5. Disconnect the 11-pin harness connector for the ignition control module (ICM).
  6. Remove the bolts from the ignition coil and the ICM assembly-to-camshaft housing.
  7. Remove the ignition coil and ICM assembly from the engine.
  8. Remove the screws that retain the housing to the cover.
  9. Disconnect the coil harness connector from the ICM.
    CAUTION When removing the housing from the cover, make sure the ground strap stays in place.
  10. Remove the housing from the cover.
  11. Remove the screws that retain the ICM to the cover.
  12. Remove the ICM from the cover.
    Fig. Removing the ICM from the camshaft cover
To install:
CAUTION DO NOT wipe grease from the module or coil if the same module is to be replaced. If a new module is to be installed, a package of silicone grease will be included with the module. Spread the grease on the metal face of the module and on the cover where the module seats. This grease is necessary for module cooling.
  1. Install the ICM to the cover.
  2. Install the screws that retain the ICM to the cover.
  3. Install the ground strap, if necessary.
  4. Connect the ignition coils connector to the ICM.
    CAUTION When installing the housing to the cover, make sure the ground strap stays in place.
  5. Install the housing to the cover.
  6. Install the screws that retain the housing to the cover.
  7. Install the spark plug boots and the retainers to the housing, if necessary.
  8. Install the ICM assembly to the engine while carefully aligning the spark boots to the spark plug terminals.
    CAUTION The ICM cover bolts must be installed using isolator washers with the rubber side facing down.
  9. Install the bolts that retain the ICM assembly to the camshaft housing after coating the bolt threads with LOCTITE, or equivalent. Tighten the bolts to 16 ft. lbs. (22 Nm).
  10. Connect the ICM 11 pin harness connector.
  11. Install the bolt to the fuel line retainer clip.
  12. Install the accelerator cable into the hold down clip.
  13. Install the cruise control cable, if applicable. Connect the negative battery cable.
Hope this help (remember comment and rated this).
Apr 05, 2010 | 2000 Chevrolet Blazer
Making the date and time show after the phone rings.
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Jan 16, 2009 | Comdial 8324S-PT Corded Phone
Comdial Dx-80 7260-00 Digital Executive Phone Logo
53 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
k24674
Tom Chichester
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
