Wont charge with new alternator and battery - Audio Players & Recorders
    Filmmaker:
    Uploaded 5 video answers.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
Perform a search for the term
"Fusible Links".
Also, double check your ground strap for your engine compartment and tighten & clean ALL power connections with a wire brush or similar.
Posted on Dec 11, 2014
Just bought engine for my cadillac escalade yr 1999 and alternator and my battery wont stay charged what can be the problem
Either the alternator is not being energized with the key on, or the main wire from the alternator to the battery/starter is bad.
Have you checked output on the back of the alternator with the engine running ?
Feb 22, 2015 | 1999 Cadillac Escalade
I change my battery and alternator and battery still won't charge
You out the alternator in incorrectly. please triple check the installation of the alternator.
Dec 20, 2014 | Cars & Trucks
Why wont new alternator charge new battery on 68 dodge
Sounds like you may have a bad battery. How old is the battery?
Jun 08, 2014 | Mopar Performance 68-69-70 Mopar B-body...
1996 cadillac eldorado new battery new alternator still wont charge
Hey Jeff. Never assume that "new" alternator is good, but lets assume it is.The actuator wire that goes into the field of the alternator HAS to be hot with the key in run position. (both wires will be). If not, it wont charge. If those two are hot with the key on, the alternator is bad.
Apr 19, 2014 | 1996 Cadillac Eldorado
My brand new alternator wont stay charged
Check the charging relay if working. You can find it in the fuse box which is either in the engine compartment or under the dashboard on the drivers side legroom.
Jan 02, 2013 | 1999 Honda Civic
Battery will not charge, first time its ever did this. rebuilt alternator new battery and new starter not to sure if new starter has anything to do with battery chargin but replaced it anyway, has good...
A bad voltage regulator could cause the problem. Assuming the alternator is working correctly. Jump the vehicle with the battery disconnected and then disconnect the jumper cables. If the vehicle dies your voltage regulator or Alternator are bad, some vehicle have separate regulators from the alternator, if it continues to run the alternator is good but the voltage regulator is probably the cause.
Aug 08, 2010 | 1984 Oldsmobile Cutlass
Alternator wont stay charged.
Replace the large wire on the back of the alternator,with a new one,it comes off the back to the positive side of the battery,leave the old one on the alternator.
Feb 08, 2010 | Pontiac Trans Sport Cars & Trucks
Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
May 02, 2009 | Honda Accord Cars & Trucks
Wont start
check for battery voltage at the charge post on the alternator and at the 2 wire connect with the key on .if you have it then its a bad alternator. if you have a belt spinning the alternator.
Feb 04, 2009 | 1990 Jeep Cherokee Limited
1993 cutlass supreme
Are you Sure the Alternator is Fine???? Sounds an Awful Lot like it is not Charging the Battery to Full Capacity.
Jan 22, 2009 | 1993 Oldsmobile Cutlass Supreme
670 people viewed this question
 Grubhead
Grubhead
