Question about Apple 13.3 MacBook Intel Core 2 Duo 2.4GHz, 2GB/250GB/SuperDrive - Black Mac Notebook
Macbook battery has an x through the battery symbol in the menu bar and the computer cannot run without charger
  • Anonymous Apr 21, 2009
    I spilt some tea over the battery, and my macbook no longer works without the charger plugged in.
    The problem is, i got a new battery and it still did not work
    therefore the problem is possibly the actual logic board, which will probably costs a fair bit
    my poor poor computer i have only had it for two weeks!
  • 211 Answers
Unfortunately its a genuine Apple fault and only solution is to replace battery.
However you can try to update battery software first:
http://support.apple.com/kb/HT1359?viewlocale=en_US
Posted on Mar 13, 2009
Battery is charged, but laptop cannot work without mains
You need to install a new power/sound board. These boards go dead on the early Intel MacBook Pros for some reason.
Oct 19, 2011 | Apple MacBook Pro - Core Duo 2.16 GHz -...
Tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 | Computers & Internet
Macbook pro says not charging
3 options..
--your charger is broken ? does it light when you plug in to power outlet ?
--Charger cable is broken ?
-- Your notebook's battery charging circuit malfunctions.(hope not)
Try with another Apple charger from your friend...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 21, 2011 | Apple MacBook Pro Laptop Computer with...
My MacBook wont charge
So does the organge light still not come on now? If it doesn't try a different charger first. If that fails, your DC-Jack module or logic board may need to be replaced. There are detailed instructions on how to do the restore online. Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Jun 19, 2010 | Apple iBook Mac Notebook
Unexpected shutdown with fresh battery ...only cycled 23 times so far. Mac shuts down after about 3 minutes....then shuts down on boot sequence after that. No warning...just shuts down instantly. Macbook...
"Shuts down instantly without warning" is the hallmark of a faulty battery. "All five lights on" is meaningless, as batteries with this fault go from 100% to 0% in a finger-snap. Assuming your battery is under warranty, it should be replaced at no charge.
Nov 08, 2009 | Apple MacBook Pro Notebook
Unexpected shutdown with new battery ...only
This is a duplicate submission -- I will be answering the other copy. Thanks.
Hi I have a MacBook Intel 2007. The other night the harddisk when carzy and the computer stopped. When I tried to reboot the screen displayed a folder with a ? symbol in the center. The Mac did not seem...
I would have put a system disk into the macbook and pressed the C key on the keyboard. This should boot the mac. Once in the instal area go up the menu bar and select disk utility and run the hard disk verify to check if the hard drive is functioning. If the mac does not boot up it is not the hard drive and then the only option you have is to take it to an apple mac authorised centre.
Aug 20, 2009 | Office Equipment & Supplies
Volume problems on my Apple MacBook
is there anything plugged into the head phone socket this threw me out the other day
actionman
Feb 19, 2009 | Apple MacBook Pro Laptop Computer with...
MacBook wont run from battery
Apple does have a battery recall/fixing procedure on certain macbooks and macbook pros.
The battery of a MacBook or MacBook Pro computer may:
  • Appear to have no charge (zero percent)
  • Be unable to power the computer by itself; the computer might work only when it is connected to the MagSafe power adaptor, which only shows a green LED
  • Appear with a black "X" icon on the menu bar
  1. Shut down, then remove and reinstall the battery. Test for the issue(s) again.
  2. Connect the MagSafe power adaptor (if you haven't already) and see if the behavior continues.
  3. If the issue(s) persist, download and install the Mac OS X 10.4.9 Update.
  4. If the issue(s) persist, Download and install Battery Update 1.2.
If, after installing the Mac OS X 10.4.9 Update and Battery Update 1.2, a black "X" still appears in the menu bar, contact apple by calling 1-800-MY-APPLE (1-800-692-7753)
Dec 06, 2007 | Computers & Internet
Apple 13.3 MacBook Intel Core 2 Duo 2.4GHz, 2GB/250GB/SuperDrive - Black  Mac Notebook Logo
130 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
