Question about Audiovox BA200 Car Subwoofer
The 6 prong input
For the power amp wire diagram
2 Suggested Answers
SOURCE: wiring diagram
I don't have an answer to this problem and I agree with the "WIZ" this amp is not very great. I would however like to fix mine.
could you do me a favor and unscrew the plate on the bottom of the amp (four screws) and look at the colored bands on R 10 so i can replace that resistor? All you have to do is e-mail them to me. It would really help me out.
Thank you.
Posted on Sep 14, 2008
How do I eliminate buzz?
Things to check:
1. With your multi meter, measure from left ground to right ground. What do you get? Measure from each input ground to chassis. What do you get there.
2. Get or make a pair of shorting plugs. Plug those into the inputs. Power on. Hum there or gone?
3. Turn the pre-amp on. Connect. Level of hum change with preamp on?
4 additional information. How efficient are your speakers? This is a big amp, high-efficiency speakers may show some noise, while low-efficiency speakers won't.
A trip back to the shop may be indicated, too.
Nov 23, 2015 | Adcom GFA-5500 2-Channel Amplifier
Wiring diagram for a Fellowes PS 60CC shredder
I own a Fellowes PS 60 shredder.
I DO NOT THINK THE LINK WILL HELP YOU, BUT AT LEAST YOU WILL HAVE IT.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jun 29, 2012 | Fellowes Powershred PS-60 Shredder
How do you hookup a universal hvac condeser motor the old one had a black wire,red and a brown wire plus the green&yellow ground the new one has a black wire a yellow then it has back connetor thats...
WHAT??? Did the new motor come with a wiring diagram? Typically you will either be using a "3 wire" connection or a "4 wire" connection. 3 wire is for using the existing capacitor (provided it's the right size), 4 wire is for using a separate capacitor. You should have 5 total wires on new motor HIGH/LOW/COMMON/CAP & CAP. Then possibly some separate wires for ground and rotation. The ground goes right where you mount the motor, rotation...make sure its blown up and out of the machine. 3 wires would be...1 SPEED 1 COMMON 1 CAP. 4 wire would be 1 SPEED 1 COMMON 2 CAPACITOR WIRES. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 10, 2017 | Heating & Cooling
I unpluged my amp from my car and i forgot where all the wires went i need help to hook back up right
There should be a group of screw terminals. They should say pos or (+), remote, and ground, GND, or (-). This is the power terminal. The power from the battery goes to the (+), the remote turn one (thin wire) goes to the one labeled remote (usually inbetween the ground and power wires), and the ground to the (-). RCA jacks should be labeled input and output. Plug the appropriate colors in the input ones. The speaker terminals are labeled left and right + and -. If it is a 4 channel amp, it will also have front and rear. Depending how you wired your speakers is how they will go to the amp. Follow the speaker wires to the appropriate prongs positive or negative. Hope this helps.
Aug 26, 2011 | Crunch Car Audio & Video
I need to switch the power cord from a four prong to a three prong. The three prong that I purchased is a 30 amp. Will it be sufficient? Only one of the strands on the three prong is labeled. The...
30 amp. will work just fine...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 06, 2011 | Dryers
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 03, 2010 | Dryers
I need help wiring a Delta 28-280 model bandsaw from 220v to 110v. The saw came 110v from the factory, but the previous owner re-configured the wiring to 220v. I need it back to 110v. Thank you.
Rewiring the motor isn't hard, but be aware that you can hurt/kill yourself if you mess this up.
That said, manual is here.
Before you start, make sure you have a couple wire nuts (orange & yellow are a good sizes), a replacement plug, and some electrical tape.
1.) Unplug the cord from the wall. Go ahead and remove the prongs since you're going to need to switch it back to a 120V type prong adaptor. Don't put new prongs on until you've got things rewired. This will help keep you from accidentally electrocuting yourself.
2.) Open the saw base and have a look at the motor. There's a cover held on by a single screw. There should also be a wiring diagram on the motor that looks something like:1aa0c59.jpg
3.) When you remove the cover you should see three groups of wires. There should be numbers on the wires, but you can also figure them out by looking at the number of wires grouped together (see wiring diagram).
4.) You want to change from three groups of wires to two groups of wires per diagram, so when you're done, 1,3, & 5 should be grouped and 2,4, & 8 should be grouped. This is assuming your wiring diagram matches mine.
Make sure you don't have any exposed copper (cover w/ electrical tape if necessary). Make sure you have the wirenuts screwed on securely. Make sure you close the cover up and put the screw back in reasonably tight.
Put the prong on the wire, plug it in, and hit the start button. If you did everything right, it will start right up and no breakers will trip. If you goofed a pair, your motor may spin in the wrong direction. Otherwise, enjoy.
Jun 04, 2010 | Saws
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
We are trying to connect an OLD Kenmore dryer which has a three-prong connection. We bought a 4-prong cord, but we do not know how to connect it as the 3-prong cord has all grey wires. Would appreciate...
Look at the plug wires. On the 4 prong plug, it should be labeled which ones are neutral. Some plugs even come with a diagram stating which wires lead where. Back to the plug itself, rule of thumb, the flattest part of the plug goes to the block, so lay the connections on the ground where they lay flat on the floor, left loop will got to left side of powerblock, right loop to the right side, the other 2 are used for a ground. look at the specs for the dryer also.
Mar 14, 2008 | Dryers
Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Aug 22, 2006 | Audiovox BA200 Car Subwoofer
Audiovox BA200 Car Subwoofer Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
