Question about Lands Phones
Terrible static on land phone
Kitchen phone terrible static. Other phones in the house are perfect. Replaced this phone 4 times....still static. Verizon was here 4 times and they cannot pinpoint the problem. One technician says when the squirrels outside run on the phone wires, I get static. that sounds crazy. Hope you can help. Thank you.
    Problem Solver:
  • 14 Answers
If the one phone is the problem, then is has to do with the wiring connection for that station. Check the wiring at the phone by wiggling the wires while on a call. If you don't want to annoy anyone, Call an 800 number that has a large menu they play.If you have a modular jack at this phone, you would want to try another jack. Try the wiggle test first. It's also possible that the other end of the cable has a bad connection, or the cable itself has been damaged and has a broken wire anywhere on the length of the cable. If you know where the wire feeds from, that would be a big step in checking the other end. If you have no clue, a technician would have to visit your home to inspect the wiring and see if he/she can find it. Another option is to feed a new cable run to that phone. Squirrels can definitely affect wiring to homes, but that affects all the phones, not just one.
Hope that helps!
Good luck and God bless!
Posted on Mar 11, 2009
Terrible static on 2.8Ghz 2-line phone Model EX 13226
do you have internet plugged in to it. You may need a microfilter which you can buy or if they came with your router .try it
Jun 25, 2009 | Uniden Cordless Phone
Static interference on Uniden 5.8Ghz phone
i have a uniden 5.8 ghz cordeless and thought it was a piece of junk as well. I had static or lapse of audio near the router, the kitchen sink, the microwave (even when off) and in the doorway. I switched the frequency on the router and changed the channels on the phones all with no luck. Short of steering clear of my entire downstairs nothing worked.
Just about ready to buy a new phone and hit up google. Saw a posting that said to keep the base away from even the tv. . .hmmm this is exactly where mine was located. So I swapped the digital answering machine base and moved it downstairs and put the additional base near my flat screen. Guess what? Problem SOLVED! I still cannot believe it.
Hope this helps
Apr 13, 2009 | Uniden 5.8GHz Dual Cordless Phone
Constant static and interference
VTech products are generally poorly designed and manufactured. You can probably notice the FCC Warnings on the device that say that you must accept all interference that you may recieve while in use. Go out, splurge a little, and find a telephone made by a well known company like Panasonic, Sony, etc.
Apr 13, 2009 | Lands Phones
Static in my phone
Do you have broadband, it sounds like you need to install a broadband filter.
Jan 10, 2009 | Avaya Lucent Partner 616 Phone
At least three different times, the phone displayed "line in use" when it isn't. All jacks and plugs were checked and all troubleshooting tips in manual tried. Two other older linephones in our...
Pull the power from all phones, and wait a few minutes and then plug them back in, if that doesn't work you have a defective base station most likely.
Jun 20, 2017 | Vtech Lands Phones
Our 5.8gh uniden phones all have static one land phone 3 extension.
disconnect the ac adapter from the base - before you plug the phone back in with power - press and hold down the menu button (center silver button under the led display) and the number "1" and then plug it back in - keep holding those two buttons until the date and time reappears - it worked for me and it didnt erase the phone numbers stored in the base unit.
Jun 01, 2008 | Uniden EXA15580 Cordless Telephone
Sounds terrible.
Be sure when you are on that phone, that you are within range, and away from any electrical interference, particularly microwaves.
Jan 08, 2008 | GE 25932 Cordless Phone
Motorola Razor V3
okay....have the phone ear piece replace.....take the phone to a professional mobile repair technician and have them replaced it.
Dec 29, 2007 | Cell Phones
Background static
1. How old are you phone lines in the house?  Check the "main" terminal connections.  Clean and reconnect.  (Make note how the wires are connected).
2. The power transformers for the phones maybe you trouble also. Unplug all except the main unit.   Check each transfer one at a time. Do you have static?  One or more may be your problem.  Replace the bad ones if needed.
Oct 04, 2007 | Uniden TRU8885-3HS Digital Cordless Phone
H700 problem with Blackberry 7130
It just so happens that I almost bought this headset, but decided not to after reading some reviews. Apparently when paired with the blackberry, the headset doesn't like to function too well. It has a severe problem with distance. Even clothing in the way of the phone and headset can cause static. I've heard some reviewers say they cannot even have the phone and headset on opposite sides of their body because it perfers to have 'line of sight' with the phone. Do some tests by connecting the headset with the phone while they are very close together, almost touching. Once it's initialized, try to keep your phone in a pocket/on your belt on the same side of your body as the phone. I have not heard why these two products work so terribly together, but the problem does not seem to point to the headset or the blackberry, but the combination of the two.
Dec 07, 2006 | Motorola Mobility H700 Wireless Headset
Lands Phones Logo
57 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
