Question about Toshiba Satellite A215-S7422 Notebook
Beep Sound on my Toshiba Satellite A215-S4807 Laptop
I have a Toshiba Satellite A215-S4807 Laptop and occasionally when i'm on it, either doing my assignments or whatever; I hear a short beep sound or long-ish beep sound. Should I be worried? What could be the problem? Does it require urgent servicing?
  • Beula May 11, 2010
    Are you running on battery power or it is plugged into the outlet. Some laptops beep when the battery is running low, or their is a change from A/C to battery.
    1. I would check and see that the battery is not running low.
    2. if it is plugged in, make sure the cables are plugged in all the way and have not become loose.
  • christian Abong May 11, 2010
    you hear many time 1 long beep and 3 short beep?..dont be worried
How can i reset bios password on my toshiba satellite A215-S4807
sir.Please condact service Engg. Or
Open your laptop and removing CEMOS battery then shotting CEMOS soket inside two connections.ok thanks
Sep 30, 2011 | Toshiba Satellite A215-S7437 Notebook
My Toshiba Satellite A215 S4807 laptop will not go pass the opening "Toshiba" page. I can't even get to the set up menu, can someone please help me. It does not respond to any of the F2, F12,...
try holding f8 key while it booting and it will take u to a boot options screen and select last known good configuration and if everything is alright with harddrive and operating system it should boot to windows
Feb 05, 2011 | Toshiba Satellite A215-S4807 Notebook
How to change dvd drive in toshiba satellite a215 s4807.
Flip the laptop over and look for a screw about 4" in from the face of the drive. somewhere towards the middle of the face. Pull this screw, eject the tray and give a sharp tug to the tray and it should slide out. If it doesn't do not continue to force it.
Jun 04, 2010 | Toshiba Satellite A215-S4807 Notebook
How to repair satellite a215-S4807 black display?
your user profile may be corrupt. after turning on your laptop press F8. choose "last known good configuration" and see if that resolves the problem. if not, next choose "safemode". from safemode click "yes" to continue and restart the computer from the start menu. if this doesn't work, go back into safemode. click "no", and restore the computer to a early date when it was working.
Nov 18, 2009 | Toshiba Satellite A215-S4747 Notebook
Compatible internal dvd rom for Toshiba Satellite A215-S4807
You can use almost any laptop cd rom, cd/rw, cd/rw-dvd rom, dvd rom, or dvd/rw that you can find. You might have to transfer the mounting pieces from the old to the new, but that is no big deal.
Should be able to find a used one for in the $20 to $30 range.
Mar 13, 2009 | Toshiba Satellite A215-S4807 Notebook
I instaled windows vista, but i need driver for video card for toshiba satellite a215-s4807. send me please the web site where i can download driver.
Download the Vista video driver for your model laptop from the Toshiba WEB site from their download page.
For a shortcut to the Toshiba's download page.
Copy and paste this address into your browser's URL address location.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
Feb 20, 2009 | Toshiba Satellite A215-S4807 Notebook
I have installed Windows XP on my Toshiba labtop A215-S4807...and I can't find the drivers for this labtop on XP. I need it immediately. Thanks,
The best to do is record your model number and go to Toshiba's website for support and search for the drivers there. Hope I Helped!
Jan 27, 2009 | Toshiba Satellite A215-S4807 Notebook
I have a toshiba laptop computer satellite a215-s4807. I cannot get it to power on. The battery went completely dead and I plugged it in to charge. But it will not power on with it plugged into the wall.
have you tried before to reassemble your laptop? if not...dont do that...because it will damage your laptop..if YES....open the laptop...remove the motherboard and replaced the power jack of the motherbaord...be sure that you find same model of the jack....if you find desolder the old jack and solder the new jack and return to assmble you laptop and put the charger and power on...good luck am 100% it will work..because this is my job..if still not work..dont hesitate to contact me..
Dec 15, 2008 | Toshiba Satellite A215-S4807 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
604 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
