Question about Maytag MER6772 Gemini Electric Kitchen Range
I have a problem with Maytag Gemini stove model #MER6772BAW when using upper oven F1-2 displays, can you give me part # to replace
fridgetech
  • 473 Answers
SOURCE: Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad.  F1-2 would be for the lower oven and F1-1 would mean the upper oven.  If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price.  These are very easy to replace.  Should be located inside the oven in the upper right or left hand side.  It looks like a silver rod about 4-8 inches long and crimped on the end.  Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done.  Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above.  Hope this helps.
Posted on Oct 19, 2007
I own the magtag gemini model MER 6770 AAW serial number 14882525YB the message I am getting from the panel is F 1-2 then it beeps until I cancel then sometimes it returns beeping. Sometimes the top oven cooks fine but if I try to cook with both ovens going it goes all crazy with beeps and shuts off and sometimes won't go over 100 degrees in both ovens. I am a very handy person and if someone can tell me how and what to replace I know I could do it. The repair center said it could be $300 plus to repair. My stove is 8 years old and I paid around $1300 for it I can't afford to replace it. HELP if it is out there otherwise I guess I will have to pay to repair it still cheaper then buying a new one...
Posted on Sep 11, 2008
  • 409 Answers
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
SOURCE: maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Posted on Dec 08, 2008
  • 2976 Answers
SOURCE: How to install Maytag oven door for model MGR5765QDQ ?
Pull the door mount bars to the first stop--where you keep the door open to broil. Slide the door back down on the bars.
Posted on Mar 08, 2009
How do you raise the surface on a maytat
Their are 2 or 3 screws under the front.
Open the oven door. Under the lip are those screws.
I have a video: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
The ovens fail to work after the cleaning cycle - displays says "call service". Now both ovens will not operate and neither do the timers.
Maytag model MER6772BAW was displayying f9-2 and call Authorized
service after cleaning also top door was locked and feature were disabled. I was able to solve the problem by unplugin the stove and waited about ten seconds before re-conecting once up the top door unlocked cleared the f9-2 error by pressing Auto set button and number 9 for Defauts. Perhaps this can help you.
Aug 14, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Ga Stove/Oven 30"
Hello Steve
Welcome
You said , We lost the instruction manual...can someone show me how to turn on the self-cleaning function on both the upper and lower ovens? Thanks, Steve O.
The instructions are to long to put in here and will not fit.
so here is what you asked for at the original site.
Whirlpool owns Maytag now so your manual is at this site and the cleaning page starts on page 12.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8113p293.pdf
Thank you for using Fixya,
Huuum
Please remember to leave a solved rating!
Oct 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oct 19, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
87 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
