Question about Tools & Hardware - Others
PNEUMATIC STAPLEGUN TROUBLE
My BEX pneumatic staplegun stopped working, looses air through release lever. How do I service it? And also, where do you put the oil in?
First, undue the four cap screws that hold the manifold on, re: top of the gun, then remove the "driver blade", with needle nose pliers. There will be a little "***", grab it with the pliers and pull straight out.
Once the driver blade is out, remove the o'ring at the top. Wrap some teflon tap around the crack where the driver blade o'ring sits about two spins with the teflon tape, then re-insall the o'ring.
put back together.
Oil goes in the "air inlet fitting at the back of the gun where the air hose hooks up, just couple drops of pheumatic air tool oil, re: 30 weight non-detergent oil, like sewing mahine oil ect. its available everywhere.
Make sure you install the driver blade the way it came out, so "watch" as you remove it. If the driver blade is busted, or cracked you'll have to replace it, can get them at any tool store or on line. about 20-40 bucks.
should work fine.
UPR, Under Pressure Repair Ent.
Kelowna, BC Canada.
Posted on May 18, 2009
  • 285 Answers
You need an overhaul kit for the stapler. Sounds like an O-ring is leaking or damaged causing air to release. If it is a decent, named brand stapler, the manufacturer usually offers overhaul kits to replace o-rings and gaskets etc.
Regarding the oil, you simply put a drop or two of air tool oil into the air connector that you hook up to the air hose. When the stapler is fired, the compressed air blows and distributes the air tool oil throughout the stapler. Usually you only need one or two drops before each daily use, but if you are firing a lot of staples in a day (say 400-500 etc), an extra drop or two after lunch or half way through the project won't hurt.
Posted on Mar 13, 2009
Put the oil into the air chuck attached to the staplegun every second or third time you use it before attaching your air hose. only a drop or two is lots.
Posted on Feb 20, 2011
What are pneumatic grippers?
air actuated fingers of sorts
Jun 08, 2017 | Computers & Internet
I don't own an air compressor. Is there another kind of power nibbler that isn't pneumatic?
Yes, there are electrical nibblers that work just as good as the pneumatic ones. of course, there are also handheld manual nibblers too
Jan 16, 2013 | Cutter Tools
Staplegun driver won't retract enough for staple to load
Check for a piece of a broken staple wedged in the driver slot
Jan 14, 2013 | Tools & Hardware - Others
Manual for chicago air impact 1/2 or other.
If you have a newer of current tool you can go to CP.COM.
If it's an older tool try this link:
Chicago Pneumatic Service Repair Parts OEM Pro Am Tools
Mar 10, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Looking for piece that screws in the handle of a central pneumatic 3/4" drive earthquake impact gun that the air fitting screws into.
Central Pneumatic (aka Harbor Freight), is usually very good for those replacement parts. On their website, to order replacement parts it says:
Please call our Customer Service Department at (800) 444-3353 Monday thru Friday, 6:00 am - 4:30 pm PST. Hope this helps... it might help to have the manual with an exploded view of the parts handy to describe what you need.
Sep 26, 2010 | Chicago Pneumatic Air Tools & Compressors
Lost the spring that holds the staples in model strapgun 12-14 how can i get new 1
No spring needed
Turn staplegun upside down. At
rear of tool, squeeze latch on
end of staple channel (see Fig-
ure 4). Pull staple channel cover
out of staple channel until it stops
(see Figure 4).
3. Drop staples into staple
channel. Make sure staple
points are facing up (see
Figure 4).
4. Slide staple channel cover
back into staple channel until it
Aug 05, 2010 | Desa International Powerfast Heavy Duty...
I have an Electric Staplegun ( Model # 34201) Wondering where can I buy the staples for it??
Try Lowes, Home Depot, Sears, and many hardware stores carry staples. Good luck!
May 16, 2010 | Garden
Cant find chisels for the Central Pneumatic Aire Chipping Hammer.
You need to order that from
Harbor Freight.
Customer Service 1-800-444-3353
9:00am-7:30pm
Monday-Friday
Eastern Time
ITEM 99792-3VGA
Mar 07, 2010 | Chicago Pneumatic Industrial CP 4123 4R...
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Mar 11, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
598 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
