Question about Betsey Johnson Gold Tone Heart Locket Necklaces On Sale
How to remove superglue from gold locket?
Superglue spilled on locket
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
How is a stauer notched leather watch band removed and replaced
No, he asked about a notched band, like on the Graves. Here the watch attaches not across the full 2cm or so but at two 6-7mm lengths around either side of a center protrusion, through which the pin slides.
Each pin consists of a longer part and a shorter end cap with a smaller pin maybe 2mm long that fits into the end of the longer hollow pin. These take a fairly serious pull to take apart, but must be pulled with care, for two reasons: one, so the pieces don't fly off and get lost when the pin comes apart, and two, so you don't accidentally torque the head sideways off the small pin, which is easy to do when you're pulling hard and not being careful. Vise-grips, with maybe thin wood like popsicle stick pieces to cushion the end caps might do, so you don't damage the end pieces as you squeeze, but again be careful. (If you do twist the endcap off its tiny pin, you might be able to glue it back with superglue (cyanoacrylate), but that's a patient precision operation by itself.)
Once the pieces are detached, the long pin will slide through the simple hole in the top and bottom protrusions from the watch case. You can customize your replacement band, set the pins, and gently compress them, again with widemouth pliers and a cushioning, they will go together more easily than they came apart.
Other Stauers use regular pins you can just pop off with the end of a pen knife, but this one is trickier.
Good luck :-)
Nov 09, 2010 | Watches
If I buy a Longines 10K gold filled watch, what is the difference between that and solid 10K gold? and is there a big difference in the price of 10K gold filled per gramme and solid
Gold filled is simply a very thin layer applied to the base metal case and will wear off over time. Solid 10K gold is an alloy that is mixed with gold throughout and will always retain it's color and never wear off. The solid 10K gold case contains a lot more gold than then the gold filled version and will cost more up front. However, the gold filled case will look awful in a year or two while the solid 10K case will last as long as you keep the watch and beyond.
Apr 22, 2010 | Longines 10K Gold Filled, Manual Wind...
I have a Junghans Mega Atomic mantel clock (grey dial with green hands) that is about 15 years old. It worked without a glitch but recently the hand of the seconds detached itself and fell. I am looking...
First, reset the clock to 0:00 hours. The instant the clicking stops, pop out the battery. The second hand stem should be at 0:00 hours. The front cover can only be removed from the bottom. Put both thumbs at the bottom of the font cover and push inward, but not too forcefully (Junghans stopped selling replacement covers shortly after dropping the product line and they are nearly impossible to find). The center should lift up enough to slide a thin credit/promotion/gift card under the center tab on the bottom. Then work the card up either slide to disengage the other four tabs. The five tabs are located at the bottom center, one each on both straight sides alligned with the top of the digital display, one at 7.5 minutes, and the last one at 52.5 minutes. That is easy part. Now comes the hard one You then need to glue the second hand back onto its stem. Superglue (cyanoacrylate based) works best. The second hand must be attached perfectly level or it could scrape the cover, the clock face, and the other hands as it rotates on a tilt. Practice a few times before applying the glue. You will notice that the socket on the second hand fits the stem very loosely. Once you are ready to glue, apply one drop of superglue on the second hand socket and mount it on the centermost stem and hold it perfectly still and in proper alignment and steady for a minute or so for the glue to set. Once the glue dries, put the battery in and let it run long enough to determine if the second hand is in correct alignment. Remove the battery again. Make certain the clock face is completely free of dust and dirt before reattachment of the cover. Insert the cover from the top down snapping the five tabs into place. It may be necessary to reverse the removal process. Then you can reinsert the battery. The process worked for me when mine was accidentally knocked onto the carpet and the second hand was detached from the force of the impact. In fact, I can no longer tell which one I performed the repair on.
Apr 08, 2010 | Watches
Remove links, too loose on my wrist
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to add or remove links. Rate me, please.
Mar 31, 2010 | Kenneth Cole Swiss Round Rose Gold Plated...
Fossil fs-4167. the small fake diamond in it is stuck on sec hand
You have to open your watch, take out stem completely, then take out whole movement and release the stone. I you have steady hands, nimble fingers and a pair of tweezers, you will be able to refit the stone using Superglue.
Jan 12, 2010 | Fossil FS2920 Wrist Watch
Stem of watch won't return to its original position
The winding crown is loose on the stem. Get the stem completely out of watch and while holding in vice or pair of pliers screw the crown back on tight. Do not overscrew it, as the stem may brake. Even better would be to unscrew the crown first, dip the threaded stem end in to the Superglue and then screw the crown back. It will prevent from the same problem in future.
Rate, please.
Jul 29, 2009 | Watches
The numbered outer ring on my seamaster fell off in the bath how
If your numbered ring was friction fitted then you will need the help of watchmaker. Very often those rings are glued. If yours was glued, get the good quality glue and just glue it back. Do not use Superglue. The best would be any good epoxy containing glue.
Rate, please.
Mar 28, 2009 | Omega Seamaster 300M GMT 2538.20.00 Wrist...
Can't open Geneve OGW154 gold wrist watch to replace the battery
You are right, this type of watch can be opened by lifting crystal and extruding the stem. As for lifting the crystal you need a specialized tool, there is no other way then to go and find your nearest watchmakers shop. If you will try to lift the crystal using knife or any other unspecified tool, you will damage the crystal. Even if you will be lucky enough to get it out without any damage, you will not be able to fit it back, because the watch crystal setting tool reduces the crystal diameter for easy fitting.
Best solution for you is to see the watchmaker and ask for help.
Do not forget to rate, please.
Feb 08, 2009 | Bulova Harley Davidson Pendant . Locket...
Mauboussin Fouga Travel Clock
I would take it to a jeweller for repair.
Apr 15, 2017 | Mauboussin Men's 18K Gold Watch
Betsey Johnson Gold Tone Heart Locket Necklaces On Sale Logo
Top Betsey Johnson Watches Experts
Jimmy Accardi
Are you a Betsey Johnson Watch Expert? Answer questions, earn points and help others
