Question about Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor
Need to charge the battery for craftsman YT3000
What type of battery charger should I buy?
2 Suggested Answers
wadembly
  • 448 Answers
SOURCE: blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Posted on Jun 27, 2010
I have a craftsman grasshog 18 v 12 in with charger and 2 batteries. I charged the batteries overnigth and the trimmer only work about 15 min on ea. batterie, after that it get weak and wont cut grass
I suggest the batteries are not up to snuff. If they last a year you are lucky. When I buy a battery operated item I keep charging them at least once a week. I have no problem now I do this.
Jul 27, 2015 | Craftsman Garden
I own a Vector Industrial Series 900 to jumpstart system and power. When we recently moved the cord was lost and now I am in need of buying the new cord. Is this availale?
I advise caution when using a standard battery charger to charge a jumpstarter via the main leads. Firstly if there is polarity protection it probably won't work and secondly the heart of the jumpstarter is a sealed lead acid battery which does not usually tolerate high charge currents without shortening the life of the battery.
This type of battery needs either the low charge current supplied by the original charger or similar or a sophisticated regulated charger.
If using a standard charger avoid using a high performance type and use only the type that provides a trickle charge.
Apr 07, 2014 | JUMP START SYSTEM
Where can I purchase a charger and manuel for a EZ Rider Wild Child Motorcycle
you could try the original supplier or ebay and failing that you could try searching online for a pdf manual and just buy any charger that is the correct type voltage and most importantly polarity, having looked at the bike its a childs harley type bike and is 6v 4ah and likely a sealed lead acid type so i would buy a 6v 500ma lead acid charger, if there is a charge port you will need a plug to match and you will need to check the polarity is correct or if there is easy access to the battery terminals you could just use the crocodile clips to the corresponding terminals on the battery itself there is a selection of chargers here 6V Lead Acid Battery Charger eBay a 500ma charger will charge the bike in 8hrs the higher the ah the faster it will charge but i wouldnt go much higher than 500ma without checking with the vendor that it is suitable for a 4ah battery hope this helps
Feb 22, 2014 | Toys
Battery charging
Only the Li-Ion batteries designed to work with the radio can be charged inside the radio. If you have Li-Ion rechargeable batteries such as those you can buy along side the
Alkalines in a store, the answer is no. This type would need to be charged in the style of charger made for recharging this brand/type of battery
Jan 25, 2014 | Motorola Walkie Talkies 2-Way Radio
Craftsman tractor making a bumping noise in front end
if it ran loose for a long period of time the slot for the key way might have been damaged pull the pulley's off and inspect them
Apr 05, 2012 | Craftsman Garden
I have a Craftsman mulcher model 315.370270. The green recharge light goes on but the battery charge level stays in the red. Do I need a new battery and if so where do I buy it?
I guess you've solved this by now, sounds like you need new batteries if the mower lacks power after trying to recharge. There are two sealed lead acid 12-volt batteries connected together on this mower to provide the 24 volts of power. These are the same batteries that are commonly used on rechargeable power wheelchairs and scooters. So you could find them at a Durable Medical Equipment company. The last two times I bought them, I got them from a DME company where I used to work. I also looked into buying them over the internet. Just make sure the replacement batteries are the same size and specs. You could burn out your on-board charger by continuing to charge batteries that are shot. I did this a few years ago with my 315.370270. Since then I have been charging the batteries with my portable Craftsman charger. The 12-volt batteries last about 3-5 years. I have had my mulcher since 1995 and have replaced the batteries about four times. This is the best mower I've ever owned. I'm going to retire it this year, if you're interested in it for spare parts.
Aug 27, 2011 | Craftsman Garden
My wii remopte won't charge. The battery dies and when I try to charge it, it only charges for about 30 seconds then says that it's charged and it's obviously not. (please help, thanks)
Your battery or charger is probably toast - this is the exact same thing my remotes did, so I went to Amazon and bought new batteries and charger - now they work fine. The batteries are designed for so many charges then they die.If, like me, you park your remotes on the charger stand when not in use that counts as charging whether or not the batteries need it so it would be better to lay your remotes next to your Wii or charger base if they don't need charging. Also - charging the batteries when they don't need it can shorten the battery's life, depending on the specific type of battery you bought. Before buying a replacement battery, find out the specific type of battery and whether or not it requires charging before getting low or needs to run out before charging. You can get this info from the seller of the battery. Hope this helps!!
Dec 28, 2010 | Video Game Consoles & Games
Recently bought Craftsman Lithium battery & charger that failed.
Sounds like your charger is only for NiCad batteries. With most brands, the new Lithium chargers will also charge the old NiCads, but the old NiCad chargers will not charge the new Lithium batteries. You will be very happy with the lithiums once you are able to fix the problem. As for Craftsman, buy Craftsman hand tools such as wrenches and sockets but I'd look elsewhere for battery powered tools.
Mar 25, 2010 | Drills
Hi, I have a motorizr Z3 phone whose charger failed. I have run out of warranty and hence I went to a store and the guy gave me another Motorola Charger that is of 6.5 Volts. My original charger was of 5.0...
hi, you need to get the same charger if the output is to high then the phone wont put the charge into the battery as it could cause it to over heat, the best place to buy one from would be the well known online auction site you should get one from their for next to nothing and this will then solve the problem.
You know the battery is not at fault as it charges from your computer via the usb lead however the charger you have brought should still charger the battery but may cause it to over heat so to me it seems like their is a fault with the new charger. Its always best to buy the exact type of charger you had in the first place as this ensures the battery is charged properly.
What phone makers do is keep the same charge connector across most of their range of phone but as phones and technology changes they start using different batteries in their phone so they have to change the charging power to match the phones battery, so the charger you have brought is probably for a newer phone with a higher voltage battery, so you need to get the correct type of charger and this will then solve your problem.
Or if you have a car you could buy a car charger as these charge the phone alot quicker as they run off 12volt so put out more amps to the phone but keeping the volts at the correct type.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
Craftsman YT 3000 42" Kohler 22 hp Gas Powered Riding Lawn Tractor Logo
27 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
