Question about Canon MG5350 Wireless PIXMA Inkjet All-in-one printer USB Cable A male
Horizontal lines with MG5350
I get horizontal lines while printing with MG5350. I have cleaned heads, checked nozzles, performed bottom plate and roller cleaning. What else should I do?
SOURCE: canon IP400
paper will not load
Posted on Jan 11, 2008
SOURCE: Black line prints on back of paper
I have the same problem and I have not found any fix yet.
Posted on May 15, 2008
tenorsax
SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Posted on Aug 17, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
ydja
  • 3 Answers
SOURCE: horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Posted on Jan 20, 2009
Why are some lines missing on a printout?
Perhaps some nozzles in the head are blocked. Try printing some extra pages or the clean head procedure.
If it does not help, remove the cartridge where the nozzle(s) are blocked from and let one drop of cleaning fluid fall on the connection tube that goes into the cartridge (on the bottom of the cartridge holder) I get my fluid in a shop where they refill cartridges.
After you dropped the fluid, replace the cartridge and again let the printer clean the heads or just print a full colour page.
Success
Jul 17, 2014 | Canon MG5350 Wireless PIXMA Inkjet...
Why is my dell 926 printer is blacking everything out
The print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Now you will be able to print in colour.
Hope this helps.
Shane
Dec 21, 2011 | Dell 962 Photo All-In-One InkJet Printer
Printer is blacking everything out
Hope this helps.
Shane
Dec 21, 2011 | Dell 926 All-In-One InkJet Printer
My printer is blacking everything out
Hope this helps.
Shane
Dec 21, 2011 | Office Equipment & Supplies
When printing a new page I get a "shadow like"
Clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged.
Hope this helps.
Shane
Feb 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
A horizontal line appears on prints every 9/32 of an inch, especially on lighter prints
The following a step by step instructions for the printer issue:
Confirm the ink tank(s) are properly installed
Perform print head alignment
Perform Print Head Cleaning - iP4500
If the prints are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleaning or print head deep cleaning. Also, you can check the cleaning results by printing the Nozzle Check Pattern after cleaning.
Remove tape from the ink tank and make sure the air hole is clear
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon Pixma iP4500 InkJet Printer
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printer update
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head. NOTE:
a. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
b. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
  1. Press <COPY> or <PHOTO>.
  2. Press <Menu> repeatedly until <USER DATA> appears.
  3. Press < (left arrow) or > (right arrow) to select [MAINTENANCE].
  4. Press <OK>.
  5. Use < or > to select [CLEANING] or [HEAD REFRESHIN] as necessary.
    [CLEANING]: Performs normal print head cleaning.
    [HEAD REFRESHIN]: Performs deep print head cleaning.
  6. Press <OK>.
  7. Print a Nozzle Check Pattern to see if print quality improved.
    4. Press <OK>.
    5. Press <OK> again.
      The machine prints a nozzle check pattern (A).
  8. If broken or white lines appear in the pattern, perform two Head Refreshings (from steps 1 through 6) then print another Nozzle Check Pattern.
  9. If print quality does not improve after two Head Refreshings, replace the appropriate ink tank.
Confirming The Nozzle Check Pattern
Broken lines
sj402061.jpg White lines
sj402062.jpg Click here to return to step x to perform Head Refreshings
Oct 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon MG5350 Wireless PIXMA Inkjet All-in-one printer USB Cable A male Logo
54 people viewed this question
old marine
old marine
