Question about Tools & Hardware - Others
MY PNEUMATIC STAPLE GUN WON'T WORK/ looses air through firing lever.How do I repair it? Where do I put the oil in?
  • David Ford
    David Ford May 11, 2010
    What is the brand and model number and I will try and help
    New Friend:
  • 40 Answers
I would agree with rowdy that the make and model number are essential to getting the right parts - If you have that information, just find a dealer that supports your brand. That being said, air leaking out the trigger area is likely to be an O-Ring or Seal problem. Pneumatic staplers have O-rings and Seals that need to be replaced periodically. Most have rebuild kits available that contain all the O-Rings and Seals that need to be replaced. Many staplers have O-rings and/or Seals on or near the trigger shaft that can wear and allow air to leak out
Posted on Mar 14, 2009
How do you load staples into a surebonder model 9630?
Loading a 995630. Hold gun upside down with front of gun in left hand. Open track release with right hand. Lay one section of 1/4" crown staples in the bottom of the gun itself, in front of the track. Slide track over staples. Store tool at room temperature. New gun needs 6 drops of air tool oil through the air inlet just before first use. If you do not have the recommended automatic oiler installed on your airline, you will need to manually oil with three drops every 3rd row of staples. Run PSI around 80 and never exceed 100 PSI on your air compressor.
Sep 01, 2014 | Surebonder Pneumatic Stapler
Tip
Power nail/staple gun
The worst pneumatic nail/staple gun is still better than the best electric nail/staple gun.
on Oct 26, 2013 | Chicago Pneumatic Air Tools & Compressors
What should I do if my brand new Fasco pneumatic upholstery stapler is leaking air through the tail end...not the hose, but the two holes in the handle? Any suggestions?
Hi Anonymus,
What's happened if the driver blade has stopped in mid stroke, the air will escape. Quickest was 'round this is to take the airline off the tool, then find some scrap wood, place the tool on it as though you're firing it, and in THIS ORDER... pull the trigger and re-connect the airline at the same time. This usually sorts this out. Regardless of the tool make and model this will happen to most users sometime....
Leigh Co Limited
May 25, 2014 | Fasco Tools & Hardware - Others
Pneumatic Hardwood floor stapler from Bostitch is misfiring
Put a little gun oil on the staples the spring that helps feed them might be catching
Dec 19, 2013 | Stanley Hand Tools
I just put a repair kit in my sx150 stapler and it fires put will not recoil i think im missing a spring in the bottom of the piston cylinder?
The Bostitch SX150 pneumatic brad nailer/stapler uses air to both drive the brad or staple and to return the driver/piston assembly to the top of the gun for the next firing. There is no spring that goes into the sleeve or under the piston. If your driver is not returning to the top of the gun you may have put an o-ring or seal in the wrong place or left one out. The o-rings and check seal on the bottom half of the driver sleeve are what control the air that returns the piston to the top so check those first.
May 26, 2012 | Stanley Air Tools & Compressors
My Makita AT1150A stapler does not shoot any staples. Air comes out around the trigger when pressed but does not do anything else. What do I do to fix this problem?
Check to see if there is any foreign object jamming the striker bar. These units also have a diaphragm that sometimes needs to be replaced. If you do not have an automatic oiler on the line the diaphragm could have cracked allowing air to pass through. The Stapler can not build up the necessary pressure to fire the striker driving in the stapler. Damaged or cracked this will need to be replaced. Not difficult and easy to DIY job. Do NOT hook up to air when doing this service. Dirt and grim can also jam the unit. Clean lightly oil, work the unit and see if it frees up. I typically put a few drops of oil made for pneumatic tools directly into the unit. Each time I pull the pneumatic tools out to use. I do not have an inline oiler. :)
Typically at the Male nipple connection where the brass female connector hooks too. 2-3 drops only!
Hope this helps!
May 26, 2010 | Makita AT1150A 716inch Medium Crown...
PNEUMATIC STAPLEGUN TROUBLE
First, undue the four cap screws that hold the manifold on, re: top of the gun, then remove the "driver blade", with needle nose pliers. There will be a little "***", grab it with the pliers and pull straight out.
Once the driver blade is out, remove the o'ring at the top. Wrap some teflon tap around the crack where the driver blade o'ring sits about two spins with the teflon tape, then re-insall the o'ring.
put back together.
Oil goes in the "air inlet fitting at the back of the gun where the air hose hooks up, just couple drops of pheumatic air tool oil, re: 30 weight non-detergent oil, like sewing mahine oil ect. its available everywhere.
Make sure you install the driver blade the way it came out, so "watch" as you remove it. If the driver blade is busted, or cracked you'll have to replace it, can get them at any tool store or on line. about 20-40 bucks.
should work fine.
UPR, Under Pressure Repair Ent.
Kelowna, BC Canada.
Mar 11, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
1,026 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
