Question about Toshiba 50L2200U 50 Inch LED TV
How do you connect a PlayStation 3 to a Toshiba 50L2200U 50" 1080p LED TV?
Help!
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: usergiude toshiba 50l2200u
Google the model number with manual or visit the Toshiba site with the same.
Posted on Sep 01, 2012
I have sound on my TV from the PS3 connection via HDMI, but no display...
From stand by (red LED) press and hold the power button, after about 5 seconds the PS3 will make a second beep. let go of the power button. This will reset your display settings.
if it asks you to display in HDMi and the screen remains black there after, just wait 30 seconds and it will default back to a lower resolution. This usually means that you have an HD READY TV which only supports 720. You can then cjange the display settings to what ever you like in the display settings menu.
Nov 23, 2014 | Sony Playstation 3 (PS3) Console
Toshiba 50L2200u no color
I'm having the same exact problem. I bought a Toshiba L2200U 50 inch and it works great with cable, but the DVD player only works in black and white. I've tried different DVD players and cables, but still no luck. Did you find a solution?
Dec 27, 2012 | Televison & Video
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
Usergiude toshiba 50l2200u
Aug 31, 2012 | Toshiba Televison & Video
Connect panasonic led tv to laptop
do one thing to connect ur laptop to tv is just shut the ******* lolz coz i dont knw how the **** to connect my ******* toshiba laptop to my panasonic led tv **** man lolz iam trying the same thing but this **** does't connect to dis **** tv it cost one rs.1.5 lak nd this **** make me angry sorry bro help me also if u gets to knw how to connect laptop to tv
Aug 10, 2012 | Toshiba Computers & Internet
HOW DO I CONNECT PLAYSTATION 2 TO MY TOSHIBA TV?
ok now goto menue seting and slect auto program with your play station runing the tv set should pick up the signinal.
Jan 09, 2009 | Toshiba MD30H82 30" TV/DVD Combo
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Toshiba TN61X81 HD Cinema Series Sound Problem
what type of connection did you use for your playstation 3 to your tv....
Aug 10, 2007 | Toshiba TN61X81 61" Rear Projection...
Toshiba 50L2200U 50 Inch LED TV Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
