My Veon 32" tv wont turn on
The TV is brand new and the very first time i set it up the screen turned on and said something about service not being available or something. while i was looking for batteries for the remote the screen went black and ever since the TV has never turned on. Even the power light doesn't turn on when i plug it into the power.
    New Friend:
Help my veon tv power is on sound is work but the screen is black ..i dont know what to do ?
Posted on Sep 28, 2016
5 Suggested Answers
  • 19396 Answers
SOURCE: Sanyo DP42746 - Screen went black and no sound. Power light on.
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Jun 16, 2009
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 196 Answers
SOURCE: AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
Different remote protocol. Probably a different series of t.v. or different manufacturer (most t.v.s are made to spec by build houses that produce for many different brands)
Jul 21, 2016 | Televison & Video
My Veon 32'' tv wont turn on
Usually fuse near cord interior in case. Teardown. Careful..VOLTAGE danger even unplugged. Touch nothing else.
Apr 17, 2016 | Televison & Video
My veon 32 inch tv screen goes blank within a second of something displaying on screen requeting to sellect a language.
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 17, 2014 | Televison & Video
Insignia flatscreen won't turn on
Your TV should be repairable. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Dec 24, 2009 | Insignia IS-LCDTV32 32 in. Television
Vizio L42, wont turn on
Usually when this happens, the TV is in Protection Mode. When the TV detects something has gone wrong inside, the TV will prevent itself from turning ON.
Try leaving the TV unplugged for 30 -45 minutes so the TV can discharge and reset itself. If this doesn't fix the problem, most likely it's a power supply board related issue. At that point, you may want to get a price quote from a local TV repair shop. The cost of fixing the TV may exceed the price of a brand new TV.
Aug 06, 2009 | Vizio L32 32 in. LCD HDTV
Tv wont turn on
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, something simple like a blown fuse inside the TV. The most common board to go bad is the Backlight Inverter Board. It what supplies power to the screen. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 19, 2009 | Akai LCT3201AD 32 in. LCD Television
Need new lcd screen for 32" sylvania
I am not aware of replacing just the front screen, that is the LCD display and is most likely more than the set cost. Please be very careful when purchasing something like this on e-bay. I can't see how they will have a display for such a new set. Can you give me a model number and I will do the homework for you?
Feb 13, 2009 | Mitsubishi VS-6043 60" Rear Projection...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Jul 20, 2008 | RCA 20F511T TV
TV Screen
im pretty sure you cant fix that you probably need to buy a new one.. i know that because my somputer has a white line that runs right down that middle, not all the time but sometimes. my father looked into fixing it and he found out that you have to buy a brand new screen or tower or something like that.
Dec 31, 2007 | JVC AV-32020 32" TV
RCA F32450 32" TV: suddenly shut off wont turn on
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
Oct 31, 2007 | RCA F32450 32" TV
Televison & Video Logo
2,524 people viewed this question
Top Televison & Video Experts
