Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Backlight stays on
Turn off back light
    Top Expert:
  • Jandy Master
  • 6,498 Answers
Go into system set up there is a backlight setting turn off or set a time to turn off
Posted on Mar 05, 2016
When car is turned off the hazard lights and the backlight on the light switch stays on
This sounds like the body control module is not going into sleep mode when the car is turned off. The BCM as it is called is located under the radio and behind the a/c controls. It is a (black box) looking thing. If you unplug the connectors to it and the lights go out then you have probably found your problem.
Mar 12, 2014 | 2008 Saturn VUE
Backlight won't turn on
your laptop probably in power saving mode, it is a preset to makes battery last longer. your power adapter might not being detected shown by red light, try to plug it firmly or use other power adapter if available
Dec 02, 2013 | Compaq Presario CQ56-115DX Laptop
Samsung LED backlighting turns off
The only cure for this is to get it repaired and stop smacking on it before you do some real damage.
Jan 24, 2013 | Samsung NP300E4C-A02US Laptop
Can i shut off the back light and or dim the
To change the backlight setting:
1.Press Menu/Ok >Settings >Display >Light Control > Backlight Control.
2.Select how long the backlight should stay on.(If you
choose Flip Open ,the backlight stays on as long as the
phone is open.)
3.Press Menu/Ok .
Thank you for using Fixya
Oct 08, 2009 | Motorola Mobility ic502 Cellular Phone
The screen light on my phone doesnt work
More than likely, you've turned the back light off all together. Go into the menu, and display settings and find the backlight options.
If it's set to 'on' and to stay on for at least 3 seconds, yet nothing works: turn your phone off and then back on again. If still nothing, take the battery out, put it back in and start it up again.
If there's still no backlight, contact your supplier or the store you bought it from.
Jul 25, 2009 | Motorola Mobility V265
Is there anyway to troubleshoot or fix the backlight on my blackberry curve myself? The backlight wont turn on.
You can go into setting and change the settings so the backlight stays on longer. But the back light Does come on when you first switch the device i.e. take battery out and back in.
hope this helps,
Thanks.
Mar 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
Tocco backlight not staying on.
Menu > settings > display and light settings > light settings > backlight time > dim> change time till dim upto 3 mins. back >on >change time light stays on .
Jan 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
20 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
