Question about Canon imageRUNNER 5000 Copier
Scan to pdf on imagerunner 5075
Hi - I had a Canon imagerunner 5075 and right now it's set up to scan to TIFF. I would like to change it to scan to PDF. Is there a way to do this remotely and make it the default for all stored addresses?
Thanks
  • 6 Answers
Unfortunately, you can't do it remotely. You have to do it at the machine. Just hit the "additional functions" button, go into "communication settings", then "TX settings" on the left, then "edit standard send settings". This is where you would set your default resolution and file type.
Posted on Mar 17, 2009
E000004-0010 error on my canon ir 5075
That means induction heater is faulty (insufficient current) and needs to be replaced.
Dont forget to clear error log after the replacement.
(copier>fnction>err>clear)
Nov 03, 2015 | Canon ImageRunner 5075 Copier : IR 5075
MY CANON 5075 TONNER SUPPLY MOTOR PROBLEM REGURALY I HAVE CHANGED MOTOR MANY TIMES BUT STILL IT GETTING PROBLEM WHAT IS THE PROBLEM
try to find the right toner for 5075 and replace it< if the problem still alive,so it's about your toner sensor
Oct 28, 2014 | Canon ImageRunner 5075 Copier : IR 5075
Want to change default scan format from .tiff to .pfd on Cannon Imagerunner 6570?
Additional Function>Communication Settings>TX Settings on left>Edit Standard Send Settings>File Format>Select PDF or Tiff>OK>Done>Done>Done
Jun 02, 2010 | Canon IMAGERUNNER 6570 Copier
Default Settings for Canon Imagerunner 3025 Scanning
You will find those settings in your scanning software on your computer, since all of them are different, there is no one right answer. Some you have to choose each time you start a new job or document.
Jul 22, 2009 | Office Equipment & Supplies
How do you set up email on a networked canon ir4570
If your machine has universal send feature installed you will need the following items
email server address i.e mail.bellsouth.net (for bellsouth dsl customers)
you may also have internal mail server, ck with IT dept to see if applicable
whether your email server requires authentication or not if so you will need login and password so email will pass from machine to server then routed to destination
settings are available and easily programmed thru the RUI (remote user interface) by typing the IP address in your browser and click on add'l functions scroll down to bottom of the page and look on right column under email and ifax settings. There is the area to input settings.
Once that is set browse to address book to enter scan to email addresses.
All can be done from main control panel also.
Hope this helps, also on the "send" page is where you go to perform the scans not the "scanner" tab. That is also where you can change file formats from tiff, pdf, or jpeg.
Regards
TankMurdock
Apr 23, 2009 | Canon imageRUNNER 1023iF Black and White...
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
TX Settings
Scroll down to 2nd page
File Format: PDF
Scanning Mode: Black 300dpi
Mar 06, 2009 | Xerox CopyCentre C123 Copier
Scanning default
yes , you have to go into additional functions under communication settings i believe you are look for a heading that reads "edit standard send settings" under here you will find what your looking for.
Feb 24, 2009 | Canon imageRUNNER 6020I Copier
Cannot scan to pdf Deskjet F2100
You have to scan with Adobe Reader in order to scan and save a pdf
Mar 31, 2008 | Canon imageRUNNER 8500 Copier
Scanning
you will need to download and install color network scangear.http://www.usa.canon.com/html/download/canonnetutils.html
the document will show up as a image, and cannot be edited. you will set the document in the feeder,place it online and then pull it over from your pc. you need office xp or higher.
or you can by universal send and scan to email, scan to a flle. Both as pdf and jpeg/tiff . this will cost a lot more and may not be worth it with a older model. if you need more help installing scangear reply back
Dec 11, 2007 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER 5000 Copier Logo
3,260 people viewed this question
old marine
old marine
