Question about Swisher ZT2454A 54-Inch Zero Turn Riding Mower, 24 HP
Need engine to deck belt size for swisher zt2454
Engine to deck belt size
5 Suggested Answers
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
  • 4 Answers
SOURCE: I have a swisher ride king mower that keeps
I have been told if the parking brake is engaged and you try to drive the mower it will instantly put a burn spot on the belt. I hope this helps.
Posted on Sep 22, 2010
SOURCE: what size belt for my
I just replaced the belt on my 44" Trailmower and since I had to get it up and running without waiting for new Swisher 4220 belt I found an ordinary V-belt 1/2"X72" whith overall with of 74" works OK
Posted on Sep 03, 2011
dambunnies
  • 49 Answers
SOURCE: I need a cable for swisher mower 60 in deck , cable supports cutting deck and helps level deck
Buddy of mine is a Swisher dealer give him a call 1- 920 - 841-7654 This is a Wisconsin number Im sure if he has one he can ship it or give you a name of someone closer.
Posted on Apr 11, 2012
What size is deck belt for swisher trail behind 44'' modelt11544
Swisher 4220 74-Inch Belt - Fits select Swisher 44-in, 42-in and 22-in Mowers
Jun 22, 2015 | Swisher Garden
Deck belt diagram
Contact Swisher to request a diagram.
Apr 06, 2014 | Swisher Ride King Zero Turn Mower 23 Hp,...
Change belt
Changing the belt on the swisher 44' rough cut - mine is a model RTB134412v. You have to remove the belt guard (4 bolts) and then the 6 bolts holding the engine on to the deck. Lift (or tilt) the engine up and loop the 1/2"x50" belt (I got a husky replacement belt at tractor supply) through the wire belt guides and around the engine belt drive. Then loop the belt around the larger blade drive. It takes about 30 mins or so. Hope that helps.
Oct 24, 2013 | Swisher 44-Inch 12.5 HP Trailcutter...
Broke engine to deck belt after only 33 hours of mowing. Swisher needs to resolve this problem. Will they stand behind their products?
I also had the same problem, belts kept breaking after a short period of time, and the problem turned out to be the four bolts holding the engine to the frame loosened to the point the engine was tilting and letting the belt slip. Once new bolts with lock washers were installed, all has been good.
Sep 19, 2010 | Swisher Zt2350 Zero Turn Radius Tractor
Swisher ZT2454A 54-Inch Zero Turn Riding Mower, 24 HP Logo
198 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
