Question about Vehicle Parts & Accessories
Heater blowing nasty skunk smell. Eventually smokes white smoke out of vents. 95' ford escort if it helps
    Novelist:
  • 187 Answers
Could be a blown heater core or steam coming through the heating system into the passenger compartment fogging the windsheild.
this means the cooling system has failed putting water in the oil and fogging the heater pipes and exhaust. replace the heater core and/or
fix the engine gaskets
Posted on May 17, 2014
  • Vehicle Part... Master
  • 17,115 Answers
With or without the motor running? See if there is a difference.
Posted on Apr 20, 2013
  • riverdwalker Apr 20, 2013
    With. And smells more when heater is running
  • Brad Brown Apr 20, 2013
    This is most likely a blown head gasket. Exhaust gas is entering the cooling system. One way to tell is to take the cap of the radiator and look for bubbles. There are more accurate ways to test BUT that should tell you. The cost to fix this is going to be over 1000
White smoke coming out of vents
i don't think it's a good idea to inhale that white smoke, whatever fluid inside the A/C is poisonous, get your AC fixed immediately. From what I can gather the evaporator inside your compartment leaks fluid and the heater core and fan blows it up your nose. I could be wrong but if that white smoke is the same as what comes out of the receiver dryer then it is quite dangerous.
Apr 26, 2014 | 1997 Ford Escort
Why does white smoke comes out the air condition vent of a Ford Explorer
The most common reason is leaking coolant, either in the engine compartment or in the heater box.
Apr 14, 2013 | Cars & Trucks
Heater vents blow blue smoke and smell of burnt leaves
Check you cabin filter it is under hood on pass side near wiper blades
If the blower motor is running fine and no smell from there.
Dec 14, 2011 | 1992 Ford Explorer
It won't move and is blowing white and black smoke
White smoke (sweet smelling, too) means antifreeze is leaking into the combustion chamber, blowing out the tail end of your truck. the boiling water in your reservoir means the pressure from the combustion chamber is pushing air into your cooling system which will eventually surface in your reservoircontainer
black smoke: it can be unburned fuel damaged turbo charger etc. light amount of smoke can be normal large amounts = problem.
Aug 30, 2010 | 2007 Ford F-350 Super Duty XLT
White smoke-like stuff comes out of heater vent of my car.
sharp acidic smell would be electrical
sweet smell would be coolant.
Feb 06, 2010 | 2000 Buick LeSabre
1997 FORD ESCORT SMOKE COMES FROM THE DASH KEEPS BLOWING ENGINE FUSE. AIRBAG LITE BLINKS.IS IT A HEATER CORE PROBLEM OR AIR BAG PROBLEM. PLEASE HELP....
The air bag module is under the heater core. If your heater core leaks onto that "blue box" it will smoke like mad.
Sep 26, 2009 | 1997 Ford Escort
95 escort smoke from vents vibration when accelerating why??
The smoke you could be seeing may be steam, your heater inside the vehicle may have a leak and causing steam to rise out of the vents, if you are smelling the steam this is what I suspect.
Engine vibration could be a number of things, check the engine mounts to start, one of them is probably broken.
Sep 09, 2009 | 1995 Ford Escort
Car smokes alot
a few things if it hasnt started in a while it will probablyt smoke..also coilpacks are notourious in going in fords also if you see white smoke it usually means water and especially if you smell antifreezecoming out of the tail pipe could also mean youhave a blown headgasket or cracked head/block another way you can tell if gasket /head/block is blown check oil and see if there any water in the oil it will be a nasty greenish color usually denotes a blown head gasket-z
Feb 17, 2009 | 1994 Ford Escort
Smoke Rollin out of my vents! HELP!
Hi
I think if it was carbon monoxide, you would have your wings by now ! .....or horns ?
Sounds more like coolant, is your Bronco smelling rather fishy these days ??
If so, it´s definitely your heater matrix leaking !
A Jar of Bars Leaks, in the cooling system might work wonders.
Good Luck !
A FixYa rating would be nice !
John.
Feb 12, 2009 | 1988 Ford Bronco
Puff of smoke from crack between heater vent and dash
antifreeze i think,heater matrix leak ,try putting a rad leak stopper in
Jan 19, 2009 | 1998 Ford Contour
Vehicle Parts & Accessories Logo
142 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
