Question about Whirlpool Calypso GVW9959K Top Load Washer
What type of wrench do i need to change u joint on Whirlpool Calypso washer
  • Whirlpool Master
  • 3,361 Answers
You will need a spanner wrench available from your appliance parts dealer.
P.S. There are several parts that MUST be replaced when the u-joint is replaced.
Posted on Mar 11, 2009
I have a Whirlpool Calypso and I have removed the washplate, lock nut using spanner wrench and u joint assy. I want to remove the metal inner basket so I can clean all the scum inside the outer wash...
Once you remove the agitator, then the nut with the spanner wrench, the basket should lift right out. It may need a little encouragement but it will lift out. I clean the out side tub with a putty knife to get the bulk of the scum off then use some cleaner like 409, or purple power to get the rest off. BE careful around the tub seal around the shaft, you don't want to damage it and have to replace it.
Jan 22, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso error code
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer display is freaking out.. It
change the panel. buttons are shorted wool button
Feb 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How do you open the top of a whirlpool calypso
You need to use a putty knife. It should slide under the "controls" and hit a spring latch. Push hard, it's not easy. The latches are on the outsides of the top.
Jan 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How to take out garmets cout underneath the
The wash plate on a Calypso is called the "nunater". The following link explains step-by-step how to remove it:
It is common for clothing to get wrapped around the u-joint, or leveler assembly. Use care when removing any garments not to damage any if these components under the nunater.
Let me know if you have any questions. I hope this helps you.
Jul 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer model #GVW9959KQ1 and its flashing CA. I bought this from a second party so I don't have a manual. What does that code mean? Where can I get a manual for this washer? Thank you,...
either that or you have a bad u joint causeing an overcurrent situation. check at the board first. make sure that you use he detergent because the regualr soap leaves a nasty build up.
Jan 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Machine - Thanks you for your Response Posting!
the class action lawsuit comprised of people who still owned their units and needed repair. what whirlpool would do is send a repair technician out on their own, they would get a list of parts for the washer and replace them when the parts came in. i own a calypso and my u joint went out and whirlpool repaired it free of charge over a 400.00 due bill to them. was just good that it never came out of my pocket. however ive since learned how to fix my unit. bt i havent had any issues with mine since the u joint and pump were replaced. i replaced the pump myself and other tuff rquired a special tool. im not sure if they are giving compensation on the washer but its worth a call to whirlpool.
Nov 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer--LD message
The LD message stands for "Long Drain".  Two possibilities could be causing this problem.  The pump could be bad, or you could have a clog in the sump.  Pull the unit out, tilt it back, and remove the bottom panel.  You need to find out if its draining at all, or none at all.  If its just a trickle, you probably have a clogged drain sump.  Bra underwires have a habit of collecting in that sump, then lint and everything else grabs on to it, and bingo, you have a clog.  Problem is, to clear the sump, you pretty much have to strip the unit down to the tub.  Not a very easy job, and usually need a special spanner wrench to remove the nut on top of the u-joint.  Let me know how it turns out, and if you need further information.  Be sure to check your drain hose for kinks or clogs as well.  Good Luck!!!!!    Jim
Oct 23, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
155 people viewed this question
Dan Webster
Dan Webster
Sal De
