Question about Bosch 24 in. SHU43 Built-in Dishwasher
Unit does not turn on or intermitent
Have repaired a break in the door panel wiring; unti was working fine, then became intermittent and has now stopped. Assume it could be the same door wiring. Other places to look?
Thanks!
  • C and B Mar 14, 2009
    Our 1-year old Bosch dishwasher cannot be started. The first repairman was unable to fix this problem. He's now telling us it's because there is a halogen light above the dishwasher, which is confusing the electonics panel. A lighting expert tells us this is BS.
    Any ideas??
  • 27 Answers
Bottom of the door as the loom passes under the drip tray it catches rubs and then breaks around thsat area new door loom is available as spare part
good hunting
Posted on Mar 11, 2009
How come I don't get any sound from my RCA rt2500 audio receiver?
I've owned this receiver since the Summer 2001 and it worked well until the audio became intermittent several years later. Eventually, the unit was ON but all sound was dead. It turns out that there are solder joints that developed tiny solder breaks. These were found in the main power board on the large electrolytic capacitors and on the 7 power tab transistors that share a large square heat sink. Thermal cycling can cause microscopic solder joint breaks over years of use. After I re-soldered the broken joints the unit worked properly and is still in use in 2017. Consult a qualified electronics repair technician for the repair, which can be accessed via the removable panel on the bottom of the cabinet. Of course, be sure the unit is unplugged from AC power before starting your inspection and repair.
Aug 21, 2014 | RCA RT2500 System
2006 KIA.DOOR LOCKS; When you unlock the doors with remote, the doors immediately lock again. With the key, door unlocks and stays unlocked. however, the feature when you turn key to the right two times...
intermittant is spelled intermittent. .... Ah, locking system. ... You will find a broken wire in one of the doors that are used to set the door lock.
Probably the drivers door return wire.
Oct 26, 2013 | 1998 Honda Civic
Passenger window operates intermittingly. When it
The problem could be in the master window switch on the drivers door, or the window motor could be going out, but most likely the cause is a broken wire inside of the weather boot that runs between the door and the body of the vehicle, and the broken wire is making intermittent contact because the door is being opened and closed all the time, and sometimes the wire will touch and make the connection and that is why it only works sometimes.
Try this the next time that the window stops working, hold the window switch down in whatever direction that you want the window to go (up or down) and while holding the switch in that position open and close the drivers side door and move or wiggle around the weather boot that contains the wiring that is between the door and the body of the vehicle, and do the same for the passenger side door, if the window starts working while you are holding down the window switch and opening and closing the door or moving around the weather boot between the door and the body of the vehicle, then there is a broken wire or even wires that will need to be repaired.
The broken wire can be on either the passenger side, or most likely on the drivers side, and if you do find a broken wire or wires, then you should repair the wires by soldering them well and use the same gage wire if you need to lengthen the wire to repair it successfully, and do not use a wire connector if you want the repair to last.
Jun 02, 2010 | 1996 Plymouth Voyager
Power window intermitant
Could be a loose or broken connector. With the door panel off, try moving the wires going to the window control module while operating the window. If you can get the intermittent behavior, keep moving the wires until you can locate a single wire. I found this to be a problem on one of mine and was able to adjust the pin in the connector to fix the problem.
Oct 06, 2009 | 2000 Oldsmobile Alero
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Intermitent problem with alternator not charging. 1998 Cherokee 6
2 possibilities, a bad wire somewhere (a break in wire) that's causing this, or a defective gauge. How often does it go to 0 volts? If you put a load on system when it drops to 0 volts (lights on, a/c on, hit the horn) does everything seem normal? If it does, it must be a bad gauge.
Mar 19, 2009 | 1998 Jeep Cherokee
Driver's door control panel doesn't work when door is open
Hi my name is Allen!
There is a ground wire that breaks between the door and the body, its inside of the rubber protector. If you peel the rubber from the door side you will find the ground wire broken.
NOTE: do not try to repair the wire at the break, because it will break again because of it bending at that location.
REPAIR: remove the kick panel trim and run a new wire from the inside out to the break, this will repair it for a long time. You must solder and heatshrink the wires together to keep moisture out of the repairs.
For further assistance contact me at FixYa!
Jan 19, 2009 | 2004 Jeep Grand Cherokee
99 town car intermitent wiper function inoperable
I performed a Web search using "lincoln wiper intermittent speed box" . There were diagrams and parts showing components. You should be able to find what you need after reading your search material. I once changed out a similar part in a 1984 Ford Thunderbird. My part was hanging behind the instrument panel and about midway up in the drivers' dash cavity.
Jul 24, 2017 | Lincoln Town Car Cars & Trucks
1995 RS Drivers WIndow does not function
use a test light , remove the door panel , unplug the wires going into the regulator motor . . check the the plug with the switch to see if you are getting power and ground .if you do , than it will be the motor. Before you do that , check all fuses , some have a fuse for the left side , and one for the right side windows .
Jul 20, 2008 | 1995 Acura Integra Coupe
Won't Power from Cigarette lighter
Recently I had a similar problem with my 300 - worked fine with AC power, but was intermittent with the power point in my truck sometimes it wouldn't power up at all in the truck).
I used a small nail file (steel wool would work too) to break the "glaze" on the outside of the small plug that plugs in to the unit on the power cord. It seems that it wasn't getting a good ground. Has been working great ever since - worth a try.
Dec 12, 2007 | Magellan RoadMate 300 GPS Receiver
Bosch 24 in. SHU43 Built-in Dishwasher Logo
89 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
