Question about Minolta Office Equipment & Supplies
Konica minolta c450 error code 2152 - Minolta Office Equipment & Supplies
  • 6,487 Answers
Unplug the power of the device for 5 minutes to refresh it and then after that plug it back on and check if the error is still there
Posted on Mar 11, 2009
  • 6,784 Answers
First, disassemble and check for any jams in the system. secondly, unplug for 5 min than, plug back into socket. if the problem is still in existence, you will need to replace the main processing board.
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
Error code c-6751 on konica minolta c450
The CCD is bad raise the document feeder. under the big glass to your left is the CCD assy. Unless you know which screws to remove you remove the wrong ones and all your images will forever be messed up. so recommend a tech come out and replaced it. have open close the front door to reset the code
Apr 05, 2014 | Konica Minolta bizhub C450 Scanner
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Minolta C450 fault code C-2656
konica minolta bizhub c450 error code c2656
Feb 09, 2013 | Konica Minolta Office Equipment & Supplies
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
Error code 2152
Trans belt retraction failure. Its a common error that can be reset by opening and closing the front door with the machine on.
Look in the trouble history and if has happened often, better order a new belt.
Jan 02, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
130 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
