Question about Philips 32pfl3504d/f7
My tv light blinks on and off and tv wont come on
I wonder if theres a reset button for the power or is it broken
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: my magnavox power button is blinking green and wont power on
sounds like a power supply issue very famous for bad power supply replacement power boards are available from www.tvcircuitboards.com
Posted on Apr 01, 2012
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Power button stuck
If the light is still blinking that means electricity goes in to the tv, you have problems after the switch , is a complicated circuit just to say where the lies.
Jan 10, 2014 | Televison & Video
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
TV WONT START UP - RED LIGHT COMES ON AND THERE IS A CLICKING NOISE AS IF IT IS TRYING TO RE START - IS IT THE LAMP UNIT OR STARTER?
if the lamp has gone the bottom light will flash if the top flashes there a problem with the tv there is reset you can do
  • Point the Sony remote control at the TV and press and hold the "Up" arrow button.
  • 3
    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on.
  • 4
    Select "OK" when shown the factor settings and the television has completed its TV reset
  • Read more: How to Completely Reset a Sony TV with a Blinking LED ' eHow.co.uk http://www.ehow.co.uk/how_6011902_completely-sony-tv-blinking-led.html#ixzz17Eijjdrn good luck regards shaun
    Dec 05, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
    Power went out now the tv wont turn on, there is just a blinking
    Does the power light just blink? Some of the Mitsubishi sets have a receiver built into them; if the power is removed the power light upon return of power should blink for 70 seconds and then go out--then the set should turn on---if the light never stops blinking---2 possible things--set should have a recessed button on the front keyboard(reset) that you can depress with something not sharp and see if after 70 seconds the light will stop blinking; if no, the set now has a damaged receiver(from the back of the set it is a large metal box on the far left side-----the blinking power light is the receiver trying to boot up like a computer---only should happen if power lost---let me know what you find----the receiver if bad is usually no longer available and can only be repaired by removing it and sending out for repair/rebuild.
    I do this here for free so if this information helped you take a minute and give me a vote here......ALSO IF YOU HAVE ANY QUESTIONS OR NEED HELP REPLY TO THIS POSTING.
    SD TECH
    Sep 07, 2009 | Mitsubishi WS-55711 55" Rear Projection...
    Kdf-60xs955 red continous blinking lamp light
    It's in standby mode.
    Do a reset and see what happens
    While holding down the reset button on the remote
    Press the power button on the tv
    (The tv will turn itself off the back on)
    Now release the reset button
    It sounds like the lamp needs replaced.
    Please rate this a fixya
    Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
    My sony TV wont turn on.
    Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
    Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
    Timer light blinks on and off and tv wont turn on
    Resetting the TV
    If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
    NOTE:
    Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
    1. Unplug the TV power cord from the power outlet.
    2. Unplug any connected devices (DVD, Set-top boxes, etc...)
    3. Press and hold the TV power button for five seconds.
    4. Plug the TV power cord back into the power outlet and turn on the TV.
    5. Open the on-screen menu to confirm that the TV is responding again.
    6. Turn off the TV and reconnect the devices.
    7. Turn on the TV.
    If ever resetting is no effect then the problem is in the "DM board"
    The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
    Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
    Philips 32pfl3504d/f7 Logo
    27 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
