Question about Garden
My countax c300h, the digital dashboard has gone off
3 Suggested Answers
  • 168 Answers
SOURCE: blades not cutting checked all belts they are ok
Either the belts are worn making them too loose, or you may have a spindle issue there. Check the spindles to make sure they aren't seized. Also, check the blade center nuts to make sure they are tight. Good luck.
Posted on Oct 09, 2009
SOURCE: My countax C300H starts OK but when I engage the
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Posted on Apr 21, 2011
Fuse blows as soon as you incert it into yhe ignition circuit on my C300H countax
You have a short somewhere and you need to trace the wiring. For your diagnosis, use "circuit breaker" fuse which will auto-trip/reset if there is a short or high amp draw. I even replaced some of my fuse with circuit breaker.
http://www.autozone.com/electrical-and-lighting/circuit-breaker?filterByKeyWord=breaker&fromString=search&newYmme=true
Mar 11, 2015 | Cars & Trucks
My countax c300h will not start
Check for spark. If it has spark, then it is a fuel issue. Try a shot of ether in the carb. If it starts, then you know it is a fuel issue. May need to clean the carbureator.
Sep 12, 2014 | Garden
Countax C300H running problems
carb jets probably need to be cleaned
May 14, 2014 | Garden
Where can i get I a new cutting deck for my old countax c300h? I am in Leicestershire and would like it fitted also. Thanks
Sorry to be the bearer of bad news - but it's either ebay, or pay Countax GBP 350 or more. Any C-series deck will physically fit, but power becomes an issue if you over-do it (don't fit a 42" deck if you only have 12HP)
May 05, 2014 | Garden
My Countax 20/50 HE electric sweeper system wont lift up
Hi Try unplugging the connector that runs from the tractor unit behind the seat to the lift mechanism. Its a little black connector and sometimes it becomes disconnected just push it together hard.
Other wisw it may be the switch on the dashboard broken.
Dave watts
Sep 13, 2012 | Computers & Internet
Countax C300H Garden Tractor Manual
I have a countax 300h about 8 years out Will not start and a warning letter C is lit up any ideas what is wrong
Apr 04, 2012 | Garden
My countax C300H starts OK but when I engage the cutters it immediately cuts out. If I let the engine run for 10 minutes then engage the cutters they usually work ok but this is pretty annoying. Is there...
Mar 26, 2011 | Honda Garden
Is it possible to download the repair manual for a countax T1200 on line
Phone Countax Customer support on 01844 278800. Tell them what manual you require, the exact model/year are on a sticker inside the console below the dashboard usually. Record the serial numbers for the deck and PGC also, they both should have stickers too. Countax will send you out a copy of the correct manual for free. Good luck.
May 14, 2010 | Garden
Blades not cutting checked all belts they are ok but not driving blades countax c300h tractor
Oct 04, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
