Question about ION Audio Audio Players & Recorders
On my lp2cd table I am getting the message system error cd write failure and then menu to reset cd write failure,what is going on?
2 Suggested Answers
SOURCE: ion lp2cd turntable error mssg
My system is an LP2CD It is bloked on
MENU TO REST
CORRUPTED PLY 1ST
Could you help me
many thanks
daniel ajzenberg
Posted on Mar 20, 2010
I cannot start windows xp. Reboot not possible. I get error message Invalid partition table. Recovery package does not work, system failure. What can I do?
Sadly, you've lost the hard disk partitions. You can try to recover that with software from Hiren's Boot CD, under Partition Tools: http://www.hirensbootcd.org/. If that won't do it for you you will have to repartition the HDD and reinstall Windows, but you will lose everything from it.
The bad news is that probably the hard disk drive is failing so you may need to get a replacement.
Jan 29, 2011 | Computers & Internet
Error 11
If the CD is going in and playing and then you are getting this message, I presume that the optical drive/ optical system could be faulty, try cleaning the lens and check . if the drive is also not working then a failure of the drive mechanism, the transport section , failure of any flexible cord could have caused the fault. Open the set and check for any obstruction to the transport. If not there could be an electronic failure within causing the error. Good luck.
Jul 06, 2010 | Pioneer DEH-P7500MP CD Player
I am facing problem in my windows XP getting error
Ok at boot up press F8, when the Menu comes up, choose Safe Mode, but this time instead of going to the desktop, choose System Restore, follow instructions, and when the Calender type window comes up, simply choose a time BEFORE, the time it went faulty. This should completely restore you to working again. As long as there are NO other problems. support.microsoft.com/kb/306084 - This is all I can think of to do.
Jun 06, 2010 | Microsoft Windows XP Professional
ION LP2CD LP vinyl record records to Internal Fla...
Same just happened to me. I was using SONY CD-R audio 80 min recordable CDs. One burned 3 songs, the other 4 songs before giving me the "CD write failure" message. I tried another brand of CD-R, TDK CD-R, certified plus, and it worked first time. It played on my CD player, on the Ion, etc - works. Maybe the CD burner in the device is very picky as to the brand or quality of the CD-R media? Try a TDK or other to see if that will do it.
-Good luck! Bill
May 19, 2010 | Computers & Internet
I have problem when i start my pc a error message appeared rcint failure string table id not found 42 at line 462
This problem usually occur due to soft booting the machine (reset) and then it could not restart. Usually after the xp logo screen u can only got the parser message: string table not found '42' at line 462. (which is a registery sincronization error (r,sint)). Click the ok button many times and your machine will boot up. Then go to control panel, user accounts, create new account. soft boot your machine again log onto new account and delete all files found in file search with stylexp and tgtsoft in them. Tthen log off and restart and log on as usual user (p.s. administrater privalidges required on both) and delete the new logon account. Hope this will fix the problem, otherwise you have to format your hard disc and reinstall your OS.
Sep 21, 2009 | Microsoft Windows XP Professional
Ink failure error HP C5180. just replaced all ink cartridges.
1. Get the unit into the “Support Menu” by following the steps below according with the product, see the table below:
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button.
----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1. Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
2. Press and release the “OK” button.
3. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
4. Press and release the “OK” button.
5. Display should say “Hardware failure status: Clear. Press OK to clear”.
6. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
7. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
8. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
9. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
10. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
11. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs replace the unit.
Aug 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
Jun 24, 2009 | HP Photosmart C8180 InkJet Printer
Ion lp2cd turntable error mssg
MENU TO REST
CORRUPTED PLY 1ST
Could you help me
many thanks
daniel ajzenberg
Dec 28, 2008 | Audio Players & Recorders
OPERATING SYSTEM NOT FOUND....NO ACCESS TO CD DRIVE
Connect your external CDROM to the laptop. I think it is a USB CDROM. Enter your bios setup. In the boot device section, try to find any option which says First Boot Device -> USB CDROM. If you can set this things then the computer will be able to boot from your external cdrom.
Nov 26, 2008 | Sony VAIO GRX550 Notebook
Error message No Disc
Unit has bad disk t-table motor
May 06, 2008 | JVC MX-J200 CD Shelf System
44 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Joseph Hoffmann
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
