Question about Genie Company Home Security
I have a genie garage door operator mod.# IS550/A and it will not open the door all it does is hum when I try to open the door even with the emergency released it just hums
When trying to open the door all the motor will do is hum even with the emergency release pulled if I turn the screw from the back side it will turn for a second then quit and just start humming
lobsterman72
  • 91 Answers
SOURCE: Sears Craftsman 1/2hp Garage Door Opener
Thats one of the symptoms of a lightning strike or a power surge. Without actually being there I would suggest replacing the back-board. But as with lightning strikes and power surges sometimes other electronic components could have been damaged as well.
Posted on Jul 01, 2008
  • 4 Answers
SOURCE: Lift-master 1265 Garage Door opener
Open case, & see if white shavings from gear stripped out are laying on bottom of case.
Posted on Dec 16, 2008
SOURCE: Liftmaster 1/3 HP - humming, but does not open.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
  • 3197 Answers
SOURCE: motor hums but door will not open
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. The part number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Posted on Jun 07, 2009
  • 17 Answers
SOURCE: my house was prewired for a garage door opener
Usually the installers will make a not at the end of the wires so that the dry wallers wont dry wall over the wires (it hapens all the time with dry wallers).I would strip off bolth wires by the garage doors.Inside the wire their will be either four little wires or two little wires strip them as well.On one garage door twist two of the wires together so that the wires contact each other.On the other garage door where the other wire comes out of the wall strip the wires (if you have four wires coming out of it you will have to use a multi meter and connect the ends of the probes of the multi meter to the same two collers of wire that you twisted together on the other door.If you have only two wires coming out of it then do the same thing you just wont have to worry about which two collers you are using.I.e. I twist red and black together on one door then I connect my probes to the red and black on the other door.Using the resistance option or the tone option on the multi meter you should be able to tell if this is a single line like I think it is.If it is a single line then the meter (if on the resistance option will read anything other then o.l.).O.l. standing for open line. (If on the tone option then you will hear a tone).If this is one line then you will just have to go to the hole in the ceiling and cut the wire in half using daulfins or barell conectors and a little wire you should be able to extend you wires.(I asume on the door opener their are two different terminals to connect two different doors).DONT pull on the wires.This will only make things worse.per state law the installers have to staple their wires to the studs and pulling on these wires can lead to them breaking off in the walls or them shorting out.It is comon for a low voltage electrican to only use one wire when installing two doors close together they just forgot to leave a little extra wire in the hole in the ceiling and then cut the one wire into two sepret wires in that same hole.
Posted on Jul 28, 2009
I am missing the lever for the bolt
Genie Screw Drive Garage Door Opener Failure - Repair ...
? 6:16
https://www.youtube.com/watch?v=htCkcs1SWvI
Feb 11, 2011 - Uploaded by sengsationa1
Genie Screw Drive Garage Door Opener Failure - Repair - Part 2 .... on the openings of the clip and wrenches ...
Prevent Garage Door Break-Ins - Instructables
www.instructables.com/id/Prevent-Garage-Door-Break-Ins/
InstructablesCatch the emergency release lever (yellow arrow) and gently pull until the ... That may work on many garage door openers, but this one is a Genie screw ... They don't care about breaking windows or making noise because they will be gone before the police arrive. ..... I am sorry to hear this is happening in Iowa now, too.
[PDF]garage door opener assembly/installation manual - Home ...
Dec 02, 2015 | Building Materials
I have a Master Mechanic Garage Door opener that I am trying to use a Genie Master Remote to operate. What steps do I need to take to operate the door with the Genie Remote?
You have to pair the remote with the opener, which will require the opener manual because you have to put the opener in programming mode.
Dec 06, 2014 | Building Materials
Can I use a chamberlain remote with a genie pro garage opener
you can try to see if it works but probably no- get anather genie remote
Oct 02, 2014 | Chamberlain 953cd multi-function 3-button...
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Home Security Logo
358 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
