Question about Microwave Ovens
I have an Emerson MW8999sb microwave and it is sparking and arcing whenever it is turned on
Whever the microwave is started it immediately starts sparking and arcing.
4 Suggested Answers
  • 25 Answers
SOURCE: The oven sparks and gives a loud hum during use.
It seems as though the container has a small amount of metal embedded in it ... don't assume just because it is plastic you can put it in the microwave.
Tip ... put just the plastic container in empty and try it. If the plastic get hot then it's the wrong type plastic for a microwave
Posted on Oct 02, 2009
SOURCE: I have an Emerson Microwave oven and I need to
MW8999SB is 900 WATTS.
Posted on Feb 16, 2010
  • 4 Answers
SOURCE: Emerson MW8999SB 900-Watt Microwave replacement plate
From what I could find, it should be 10 1/2 inches in overall diameter.
meowpfttpftt
Posted on Mar 31, 2010
I have a emerson mw8999rd that started crackling and sparking what cause this and can it be repair?
Sounds bad. Most likley caused by the magnetron tube arcing to the waveguide. Repair may be possible, but would be expensive (more than the microwave is worth). And if the arcing was severe or occurred for more that just 2 or 3 seconds, the waveguide may be damaged, and that is unrepairable.
Oct 20, 2014 | Emerson Red Mw8999rd Countertop Microwave
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
I HAVE A MICROWAVE MODEL EMERSON MW8999SB IS NOT HOT
I unplugged mine and let it sit for a few mins then plugged it back in and it works again....Yeah Me!!!!!!!!
Jun 08, 2012 | Emerson Microwave Ovens
Emerson mw8999sb rattles when running?
It is probably the turntable glass platter that is rotating when the microwave oven is running, this is not uncommon and nothing to worry about.
Mar 26, 2012 | Emerson Microwave Ovens
I have a emerson mw8999sb microwave. When not in use it makes a weird staticky sound, the really weird thing is that it does it even when it is unplugged. Can any one help me with this issue
Have you found an answer to this yet ? My same model started doing this last night. I purchased it back in probably March sometime.
Jan 04, 2011 | Microwave Ovens
meowpfttpftt
Mar 31, 2010 | Microwave Ovens
Put in bag of crab rangoon. bag had foil on inside. i saw it spark into small flame. shut of IMMEDIATELY. now there are 2 read lights on display. can't make out what they are and the manual does not...
Anytime you have arc welding in the microwave, its not a good sign. You may have burned out the megatron tube. The red lights are obviously warning lights. If you canot contact the mfg for the correct reading of these lights, you may want to get another unit.
Oct 20, 2009 | Emerson Fans Emerson MW8115SS Microwave...
The oven sparks and gives a loud hum during use with plastic food containers. This scares my wife and mom terribly. I have an Emerson 900W microwave oven (model:MW8999SB).
Oct 02, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
