Question about Samsung LN32A330 32 in. LCD TV
LG 32LK330 no signal from cable box - Samsung LN32A330 32 in. LCD TV
How do I repair an LG 32LK330-Ub Auto channel tuning does not work.
If you have a cable box and your cable is attached with coax to the antenna or cable input you're probably receiving everything on Ch 3 or 4. If you don't have a cable box, then make sure the input / source is set to cable and not antenna.
Dec 03, 2014 | LG Televison & Video
I need to unlock my 32LK330-UH tv
Google the model # with the question of how to unlock.
Nov 24, 2014 | LG 32LK330 TV
HOw do I remove the base from a LG 32LK330 flat screen TV
Lay the tv screen facing down on something soft like your sette or bed so the base is hanging over the edge.
At the back you should see screws on the base, if not visible they will be under a cover which should prise off
Dec 31, 2013 | LG 32LK330 TV
My lg 32lk330 will not turn on
It is likely that your LG TV will not turn on because it has a power supply problem
Feb 26, 2013 | LG 32LK330 TV
Forgot my lock password lg tv
You can check this service manual for this TV.
There is information on page 76 about LOCK settings.
If you forget your password, press '0', '3','2', '5' on the remote control handset.
service manual
Dec 19, 2012 | LG 32LK330 32" Class LCD HDTV -...
What is the service code of LG32LK330
mine is on back of tv 32lk330-UB.CUSDLH
Oct 27, 2012 | LG 32LK330 TV
I would like to run my technics stereo on my new lg tv so what lead do i need any help pls?
You can get a standard Audio / video cable with 3 or 4 RCA cable.
Jul 23, 2012 | LG 32LK330 TV
Hello I received a lg flatron plasma MZ42PZ14 and just wanted to connect the tv cable to the tv, but i can't find any coax on the tv. what can i do?
This kind of tv u must have cable or satalite tvs pay broadcasting signal cable,so u have a box .Tv have HDMI ports or RCA AV component cable input?The incomming broadcating tv signal go to the cable or satalite boxes.Than u use a HDMI cable or RCA AV component cable go through those boxes than to ur tv HDMI input ports or RCA AV component cable input holes.
Jan 22, 2011 | LG MZ-42PZ14 42 in. Plasma Television
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
Can not get the listings for the TV Guide to load. The TV is connected to cable box and tuner with HDMI cables. When I contacted LG they stated that I need to split the cable signal prior to connecting...
Hi my name is Roety,
I can help you with your issue ,
The cable box signal is received from a round cable called coaxial cable. The guide is sent to the cable box through the coax cable. The HDMI cables sends the picture to the TV.
The Tv does not download TV guide listings , just the box does. That would be a cable company/box issue not a TV issue.
Some TVs have a built in TV guide for when you recieve signals from an antenna (not cable).
If thats what you are referring to don't bother .
Use the cable box guide .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | LG 50PX4DR 50 in. Plasma TV
Samsung LN32A330 32 in. LCD TV Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
