Question about Craftsman 1983 Sears 572.247202 15" Motorized Scroll Saw Sander Manual blades
How do you change blade on a scroll saw? - Craftsman 1983 Sears 572.247202 15" Motorized Scroll Saw Sander Manual blades
3 Suggested Answers
SOURCE: saw blade broke. motor won't run after changing
It would have cost more to have Sears fix the saw than I paid for it, so I got my meter out and by checking the voltage drops across all of the electrical connections in the saw , I determined that the on / off switch was defective. This switch is the same switch used to turn the lite on and off, so I took the switch out of the lite and used it in the saw. I ordered a new switch for the lite and will install it when the new one comes. Thanks for your interest and help. fletcher1
Posted on Jul 21, 2009
al_kupchella
  • 843 Answers
SOURCE: How to change the blade on a craftsman scroll saw?
You might be able to find the manual on the Sears site (this can be a frustrating search - but start with the model number). But even without the manual, this is pretty easy on most scroll saws. There is usually a plastic knob (about the size of a ketchup bottle lid) on top of the machine at the back. You loosen this knob a couple of turns (to the left) and the blade will become very loose. The blade is probably the "pin-end" type - it will have a little cylinder about a 1/4 inch long on each end of the blade. You can buy new blades at any home improvement or hardware store. Besides qualtiy, the main differences will be the length of the blade and the size of the teeth (expressed as TPI or Teeth Per Inch). You need more TPI for cutting harder and thinnner materials, less TPI for softer and thicker material. Put the new blade in like the old one was (teeth pointing down) and tighten the plastic knob. It's hard to be sure how tight is should be, since it doesn't suddenly tighten up. About a 1/4 turn past where is starts to get noticeably tighter is a reasonable place to start. If the blade pops off during use, it wasn't tight enough.
Posted on Jan 19, 2010
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
Need a owners manual for 40-130c scroll saw need to change the blade. type and how to
Hi Jean:
I get worried when I see questions like yours.
A scroll saw can be a DANGEROUS tool.
If you don't know how to change the blade, I sincerely suggest that you should get some qualified instructions BEFORE you try to use it.
Please, for your safety, get some training.
Sincerely.
Mar 20, 2016 | Saws
How do I change a saw blade on a scroll saw
Which Scroll Saw are you using...there are multiple brands and multiple models. Help us out and tell us which one you have.
Most of the time there is a clamping mechanism that holds the top of the blade in place. Many models have a door or some access point to the lower end of the blade, too, which you'll have to get to as well.
You'll also usually find that there is some type of blade tension device that needs to be released and then reset before you can install and use a new blade. Make sure the new blade is the same length as the old one, also, make sure that it's the same type of blade, some have a small pin top and bottom, some do not.
Finally, check out YouTube and see if anyone has put up a video for your brand of Scroll Saw. May be the answer.
Good luck and be safe.
Oct 09, 2014 | Saws
Would I be able to replace the blade on my scroll saw? How would I go about doing this?
It is possible to replace the balde on your scroll saw when it gets dull. Make sure that you do change the blade to be very careful because the new one will be very sharp. Following the instructions on this site will help you out. http://www.doityourself.com/stry/how-to-change-a-scroll-saw-blade#b
Jan 02, 2014 | Saws
I can't see how to change blade. Do I need to take off the table part? I can't get to the bottom attachment part I have the 16'' Ryobi portable scroll saw
Theblade has a small rod on each end that locks the bladeon.. Pull the blade outward and pressthe top arm downward to remove the blade
Jun 02, 2010 | Craftsman 16" Variable Speed Scroll Saw
I have borrowed a Makita SJ401 scroll saw. How do
Scroll saws generally have to be loosened in two spots. One spot is above the blade near the tip of the arm. The other is generally below the plate. Most scroll saws come with a special tool that has an allen wrench type end accompanied by a round peg that is inserted just above or below the spot for the allen wrench.This peg type end helps to hold the tool in place and keeps the saw arm from moving around. The other end of the tool has a handle.
Hope this helps.
Nov 06, 2009 | Plumbing
KEEP BRAKING THE BLADES ON MY SCROLL SAW.
chances are you might be trying to feed the wood to fast or your speed is set wrong or the blades are not right for the job.
Oct 24, 2009 | Saws
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Oct 22, 2008 | Dremel 16472 Carbide Coated Scroll Saw...
Craftsman 1983 Sears 572.247202 15" Motorized Scroll Saw Sander Manual blades Logo
52 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
