Bosch 24 in. SHU53 Built-in Dishwasher Logo
rob slowin Posted on Aug 02, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shu5312uc bosch dishwasher
For some reason once the dishwasher gets down to 38-35 minutes on the counter it just keeps washing and doesnt count down any further...so it keeps running. I have to shut it off. From what I can tell water is hot and not running due to excessive bubbles.
  • kbcanada Mar 11, 2008
    I have exact same problem with dishwasher getting stuck at the 38 minute point in the countdown. Drains fine if I use the Rinse/hold cycle or use the interrupt cycle buttons. Please post if you solved the problem.
  • Anonymous Mar 27, 2014
    does not wash with hot water and gets stuck on 18 minutes
Anonymous
Level 3:
  • Master 641 Answers
  • Posted on Aug 02, 2007
Anonymous
Master
Level 3:
Answers
641
Questions
Helped
957802
Points
1616
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Bosch dishwasher counts down to 001 and stops can not cancel the 1 minute left
Very common"no heat" error for bosch to stay at 1 min. If the water doesnt get hot enough, it will never finish cycle
My LG dishwasher counter doesn't count down
Since you didn't give the model number, I looked at a general user manual for an LG dishwasher. It suggested that if the water is cold, it would take longer to wash the dishes. That suggests to me that a cold water temperature might prevent the timer from starting till the desired temp is reached. Could that be the problem? Could it be connected to a cold water supply rather than hot? Is the hot water set too low?
2helpful
My Bosch diswasher SHU5312UC runs down to one min and won't pump the water in or out.
hi,theres a overflow swich it the pan under the dishwasher...it might be sticking or your control board behind the disply for 1 min..is bad...call i will fun you through it...
3helpful
My bosch dishwasher model shu5306 uc/u12 counts down to one minute left then just keeps running
Your d/w has a faulty control board... only solution is to replace it.
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
5helpful
2answers
Bsoch dishwasher runs long and displays 1 minute left on timer
sounds like a bad solder connection on the heater relay of your control unit. more than likely you will need a new control unit. part number 266746
Replacing Control Module
Sergio,
Did you get your problem resolved. By now I think you have found the two screws on the sides of the inter part of the door. Did replacing the module fix your problem. I have the same problem.
Mike
7helpful
3answers
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
2helpful
Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
