Question about Acer eMachines 520-2890 Notebook
Problems with my Emachines 520
When i turn it on the power light comes on and the screen goes grey then stops. No start up screen, nothing. Please help
  • lynette_cook Mar 12, 2009
    It spins for about a second then stops and then nothing, no windows login, just a grey screen and the power light on.
    Thanks
  • dereknewland May 11, 2010
    Do you hear the hard drive spinning like it normally would during startup? Do you here the windows login sound?
Laptop continuously shuting down
Probably it's the cooling system, or maybe it's the motherboard...
You turn it on, and then it apears the screen with the laptop brand or something?
Apr 09, 2013 | Acer eMachines 520-2890 Notebook
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
My e525 laptop starts up, and after the big "e" logo the screen goes blank.* Whenever I press a key there's a loud beep. How do I fix this? *As far as I can tell the screen is blank, but it's...
Try this... 1. Remove the battery 2. Remove the memory for about 5 minutes 3. Re-insert the memory 4. Press ESC for about 3 minutes while putting the power adapter. 5. Then turn on without battery.
Mar 11, 2011 | Acer eMachines 520-2890 Notebook
Had trouble booting the computer over time. Sometimes power light would come on and nothing else. By unplugging, waiting 15sec it would power up. Over time this stopped working. Eventually power light...
Time to look for a new computer. That and take out your hard drive to copy your files over.
Sounds like motherboard problem. Probably not worth repair.
I've got an HP desktop with similar problems. It turned on one day just fine. The next day not. I don't even get the boot up screens. Disconnecting Hard Drive and CD/DVD components do not help. I should at least get some BIOS POST beeps and a Hard Drive Not Found or such. I do not. On occassion it will boot to a blank screen with white cursor in upper left. Most the time no screen at all. On rare occassion it comes right on and boots Windows. I guess it could be the power switch ... but I doubt that.
Nov 22, 2009 | E-Machines eMachines Desktop PC
My e machines e520 wont come on the power light is on and the fans are working and the battery light if i plug it in but nothing else and the screen is blank like its off
Try by removing the battery. Try external monitor. check your Monitor/lcd setup by FN keys. If this is not solved, You may have
1- Inverter problem
2- Graphic card problem.
3- LCD bulb is not good anymore.
4- If you upgraded the memory, Try to test one by one, (Remove battery and power before process)
JMC
Aug 15, 2009 | Acer eMachines 520-2890 Notebook
Emachine E525 was fully locked
não consigo de jeito nenhum achar o drive de rede para o emachines e525
Jul 01, 2009 | Acer eMachines 520-2890 Notebook
Acer labtop won't start...but power light is on
Seems your laptop is overheating.
When it overheats, the laptop shgutsdown as a defense mechanism, to protect important parts like processor.
Check the fans and remove all dust from them with a vacuum..
If that doen;t help, you;ll need to perofrm a deeper cleaning of the heat sink and apply a fresh heat transfer compuond at the CPU.
You mention you have your laptop since 2006.
I would say its about time for a deep clean up
Please don't forget to rate this answer if you find it helpful
Thank you
Jun 25, 2009 | D-Link DU 520 (DU-520) Serial Adapter
No display on the Dell Dem 520
IT SOUNDS LIKE HARD-DRIVE FAILURE, TRY REINSTALLING THE OPERATING SYSTEM, BUT IF IT DOES NOTHING THEN REPLACE THE DRIVE
Jun 16, 2009 | Dell Dimension E520 PC Desktop
Acer eMachines 520-2890 Notebook Logo
190 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
