Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Garbage disposal...won't drain
Put cooked pasta down disposal (quite a lot), added water and started to grind.... water level began to rise and watery pasta mess swirled round and round for several minutes.... now standing water going nowhere!
  • marybethfinn Mar 11, 2009
    i was running the water when i put the pasta in...why would i press the reset button if the motor hasn't jammed?
  • marybethfinn Mar 14, 2009
    I was afraid of that!! my son is coming over sunday...afraid that is beyond my capability...don't do wrenches in an upside down position!
  • GE Master
  • 3,361 Answers
There should be a reset switch on the bottom of the disposal.
When using a disposal, always run water first, then turn on disposal. Then dispose food. Then keep water running until it all sounds clear before turning it off.
Posted on Mar 11, 2009
  • steve
    steve Mar 11, 2009
    .I apologize. I misunderstood your problem.
    Remove the p-trap under your sink and clear the blockage.
Kenmore Quiet Guard is clogged on the bottom. Leaking water.
take out the bottom rack, pop out the center. use a snake on the drain. if not aviable us a wirer coat hanger. the water should go down. to top it off ad some draino or something like that. but rises your dishes before you put it in the dishwasher. remember a dishwasher is not a garbage disposal. run the dishwasher again i wish nothing in it. that will flush out the drain. then your good.
Jan 02, 2013 | Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher won't run. Worked yesterday, checked curcuit breaker, ok. water is in the bottem of washer but below the float level.
First, check the dishwasher filter and make sure it isn't clogged. Your owner's manual will have simple instructions on how to access and clean your dishwasher's filter.
Next, check the drain hose. Does it look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food. If that does not get the machine draining, you may have a deeper clog. However, most drain hoses clog either at the main household sink drain line connection or the garbage disposal connection.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process, so you may need an entirely new timer or a new motor for the timer. Repair service is recommended.
In some dishwashers, standing water is caused by a valve that fails to open and allow the water to drain out. This valve is controlled a solenoid that the timer controls. A malfunctioning solenoid could be the problem.
For more troubleshooting tips and solutions, see Dishwasher not draining. I hope this helps!
Sep 27, 2012 | Kenmore 665
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Water not draining out
Look where the drain hose attaches to the garbage disposal. Make sure the knock out plug has been removed.
Feb 23, 2010 | Dishwashers
I have a Bosch dishwasher that was working just fine until I spilled a bag of uncooked pasta. I sent the pasta down the drain and ran the garbage disposal, subsequently clogging the pipes. I had to get a...
It may simply be where the dishwasher drain attaches to your garbage disposal. There should be a hose clamp and can easily be taken off. If the clog's not right at the connection, chances are it's far. If there is an air gap, it will be within a foot of the connection. Just shake the DW drain into a bucket and you should be good to go. Not sure why the plumber wouldn't do that though....being a plumber, I would never leave a customer with a clog. Anyway, good luck!
Jan 24, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
My quiet partner 4 will no longer drain, I recently replaced my garbage disposal & the problem began after that.
There is a plug you have to remove on the garbage disposal where you hook up the washer drain hose.
Check the instructions with the disposal.
You'll have to deinstall the garbage disposal, remove this plug and reinstall.
May 05, 2009 | Dishwashers
LGDishwasher makes grinding noise several times during cycle
Please confirm that you have an LG LDS 5811 dishwasher? Approximately how many years old is the dishwasher?
First things first: regarding the 'crud' Run at least one cycle, with no detergent powder added - and when you go put in the extra water, add up to two cups of vinegar plus more water and let it run until it errors. This will not fix the major problem, but staring with a clean sump area (and keeping it clean) is a good start. FYI: Stop using all gels and tablets, switch to a brand name detergent powder-like Electrosol or Cascade. Always use high quality powder in all dishwashers, especially energy and water conserving DWs like the modern LG models.
Next, given that you are getting an E! code, triple check that you do not have a leak, especially directly under the dishwasher. If not, start at the end of the DW drain hose (does it connect to a sink disposal?) follow it back to the DW. That hose must rise to at least the height of the bottom of the counter top or be connected to an Air Gap valve. If the hose does not have that rise in it, your problem is caused by natural siphoning out of the dishwasher into the drain. Either add an air gap (even if you don;t have a sink disposal) or suspend the hose high from the bottom of the counter.
Regarding the filter (mesh screens) in the sump area, while it may be melted, I doubt that melting was caused by the dishwasher itself, because the heating element is well below the filter.
Pull the lower spray arm up and out. Remove the nine phillips screws that hold the filter down and then pull the filter. Wash out the "self cleaning" filter housing.
The LG replacement part for the upper housing with the mesh screen panels is: FILTER ASSEMBLY, MESH 5231DD1001A I also recommend you replace the filter seal: SEAL 4036DD3001A
Then inspect under the filter in the sump area for any debris. Remove it but watch out for broken glass! Use a flashlight and look real close for anything foreign.
Inspect the Impeller, look for damage and confirm that it spins easily but is securely attached.
Reassemble and test out.
Good Luck!
Apr 04, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Garbage disposal spouting water after turned off
Hello, turn on the disposal without water and pour hot water into disposal. Be careful not to let it splash back on you! If this doesn't help you have to remove the drain and drain trap and clean them out. If you need more help let me know. Good luck.
Jan 23, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
227 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
